この分解で使用される工具
はじめに
This is only a simple teardown to take out all components that can be easily switched out.
分解
この分解は修理ガイドでは ありません。 お持ちのHTC Evo 3Dを修理する際は、iFixitの修理ガイドをご利用ください。
Vibrator come's out easy, Just grab it by the wire and give it a little tug and it should come out.
Start unlocking the clips holding the ribbons. pull the white tab up to unlock.
Example: bottom left is unlocked, bottom right is locked. upper left has bin finished and removed.
Tuck the ribbons in without bending or making tears in them.
Behind the main board is two more ribbon's.
Flip both tab locks holding the ribbons and they will slide out vary easily, Don't force it.
Wifi/cellular antena port, Lift up cord head directly to remove and press straight down centered to put back on.
As a side note, the grey tape on the back side of the board was covering the clips so i cut a small section for this guide.
ご自身のサイト/フォーラムに小さなウィジェットとしてこのガイドを埋め込むには、サイズを選択し下のコードをコピーしてください。
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 19,041
