メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのApple USB Power Adapterを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Apple USB Power Adapter Teardown, Separating the input panel: 手順 1、 3の画像 1 Apple USB Power Adapter Teardown, Separating the input panel: 手順 1、 3の画像 2 Apple USB Power Adapter Teardown, Separating the input panel: 手順 1、 3の画像 3
    • Use a hammer and a small chisel to carefully force the input panel open
    • Clamping the device helps prop the input panel open but, do not pull the panel away from the device forcefully, as there are small wires connected to the device components.
    • Be careful not to force the chisel into the device as you could damage internal components.
  2. Apple USB Power Adapter Teardown, Removing plastic casing: 手順 2、 2の画像 1 Apple USB Power Adapter Teardown, Removing plastic casing: 手順 2、 2の画像 2
    • Use dyke and pliers to cut outside casing to pry open the shell and remove the circuitry.
    • Recommend using hand saw to cut around the plastic.
    • Be careful not to cut forcefully as to prevent the internal components from getting damaged.
  3. Apple USB Power Adapter Teardown, Isolating internal components: 手順 3、 3の画像 1 Apple USB Power Adapter Teardown, Isolating internal components: 手順 3、 3の画像 2 Apple USB Power Adapter Teardown, Isolating internal components: 手順 3、 3の画像 3
    • Isolate the internal electrical components from the casing
    • Recommend unsoldering the wires from the input panel.
    • For help desoldering connections, follow this useful guide on はんだ付けとはんだ除去の作業ガイド.
    • Use caution when soldering. The heated tip may cause damage to the board, the components, or burn you.
  4. Apple USB Power Adapter Teardown, Accessing individual components: 手順 4、 3の画像 1 Apple USB Power Adapter Teardown, Accessing individual components: 手順 4、 3の画像 2 Apple USB Power Adapter Teardown, Accessing individual components: 手順 4、 3の画像 3
    • Unsolder components that connect to the bottom and top circuit boards.
    • Detach the top and bottom circuit boards from the plastic separator.
  5. Apple USB Power Adapter Teardown, Exploration: 手順 5、 2の画像 1 Apple USB Power Adapter Teardown, Exploration: 手順 5、 2の画像 2
    • Observe that once the circuit boards are separated individual components can be accessed.
作成者
2人の作成者と共同で作成されました。
Juan Gonzalez
メンバー登録日: 01/24/19
422 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019人のメンバー
CPSU-WHITE-W19S18G1
4 メンバー
21のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 51
過去 30 日: 217
今までの合計 15,719
