メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのApple DVI to ADC Adapterを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Apple DVI to ADC Adapter Teardown, Remove Sticker Screw Cover: 手順 1、 3の画像 1 Apple DVI to ADC Adapter Teardown, Remove Sticker Screw Cover: 手順 1、 3の画像 2 Apple DVI to ADC Adapter Teardown, Remove Sticker Screw Cover: 手順 1、 3の画像 3
    • Turn the device upside down so that the information printed on the back is visible.
    • Carefully peel the sticker using a screwdriver from an edge. This will reveal two Phillips screws.
  2. Apple DVI to ADC Adapter Teardown, Bust the Plastic Housing Open: 手順 2、 3の画像 1 Apple DVI to ADC Adapter Teardown, Bust the Plastic Housing Open: 手順 2、 3の画像 2 Apple DVI to ADC Adapter Teardown, Bust the Plastic Housing Open: 手順 2、 3の画像 3
    • Begin to open from the cable side. Carefully lift the side up like you would a hinge. The clips should un-clip themselves.
    • There are plastic clips that hold the casing together on the other side.
  3. Apple DVI to ADC Adapter Teardown, Removing the Shielded PSU: 手順 3、 3の画像 1 Apple DVI to ADC Adapter Teardown, Removing the Shielded PSU: 手順 3、 3の画像 2 Apple DVI to ADC Adapter Teardown, Removing the Shielded PSU: 手順 3、 3の画像 3
    • Remove all four screws on the edges of the PSU.
    • To remove the last screw, remove the shielding tape.
    • Be careful not to pull on the PSU too hard. there is a connection to the logic board.
    • Carefully peel the shielding tape to release the PSU from it's place
  4. Apple DVI to ADC Adapter Teardown, Release the PSU and Deshield the Logic Board: 手順 4、 3の画像 1 Apple DVI to ADC Adapter Teardown, Release the PSU and Deshield the Logic Board: 手順 4、 3の画像 2 Apple DVI to ADC Adapter Teardown, Release the PSU and Deshield the Logic Board: 手順 4、 3の画像 3
    • Pull the shield towards the cable side and it should pop open. (Some force is required).
    • Disconnect the PSU connector.
    • PSU is free.
  5. Apple DVI to ADC Adapter Teardown, Removing the Logic Board: 手順 5、 1の画像 1
    • Unscrew the logic board and pull it out
作成者
1人の作成者と共同作成されました。
alienozi
メンバー登録日: 02/17/20
146 ポイント
1ガイドが承認済み
コメント 1 件
Great teardown and history lesson! I didn’t know what ADC was—a proprietary Apple interpretation of DVI. Apple hasn’t changed a bit, for better or worse. The world is a better place for it though :)
iEvan - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 2,392
