2013 unibody MBP battery replacement
問題
After approx. 600 cycles, diagnostics on the battery indicated one of the cells was bad, generating a service battery notification. Apple Store wanted $200+ to basically replace the top case assembly and battery, plus wanted to keep my work MBP for a week.
修理
Repair went exactly per the guide, no problems at all.
アドバイス
Take your time. Don't try to force anything. ALWAYS label parts and take photos on removal. Be judicious with the acetone in removing the battery adhesive, no need to flood it. Also no need to wait the 2-3 minutes per the guide; 30 sec to a minute is enough. Photo in place or label aircard antennas prior to disconnect to ensure you reinstall to the correct contact heads.
0 件のコメント
