問題
Battery would not hold a charge. Even if you didn't use the phone, it would go from fully charged to about 60% in an 8 hour day.
修理
Not too bad. Longer than I expected, due to issues with getting the tiny screws to stay in place to secure them back to the logic board.
アドバイス
These screws are very tiny and hard to manipulate. The screwdriver is magnetic; which is great to take them out, but makes it hard to put the screws back in, as the screwdriver pulls them from the hole. I solved this problem by using the pointed end of the spudger to put a tiny drop of Elmer's glue in the hole and then insert the screw. You can do this before putting the bracket in place if you want. Then the screw wont pull out by the magnetic driver and make lining up and fastening the screws much easier; at least for me!
0 件のコメント
