修理を始めるには
修理する権利
ストア
MacBook Air 13" (Mid 2013-2017) I/O Board Cable
  • MacBook Air 13" (Mid 2013-2017) I/O Board Cable
$19.99
$19.99
製品詳細
商品名
商品名
Replace a malfunctioning or torn I/O Board Cable in your Mid 2013 to 2017 13" MacBook Air laptop.
Fix the connection between the I/O Board and the Logic Board.
互換性
互換性
  • MacBook Air 13" A1466 Mid 2013 to 2017
仕様
仕様
Part #:
923-0440, 821-1722-A
互換性
MacBook Air 13" Early 2014
A1466 (EMC 2632) 1.4 GHz
A1466 (EMC 2632) 1.7 GHz
MacBook Air 13" Early 2015
A1466 (EMC 2925) 1.6 GHz
A1466 (EMC 2925) 2.2 GHz
MacBook Air 13" Early 2017
A1466 (EMC 3178) 1.8 GHz
A1466 (EMC 3178) 2.2 GHz
MacBook Air 13" Mid 2013
A1466 (EMC 2632) 1.3 GHz
1以上のデバイスを表示
修理にまつわるストーリー
ユーザのアバター
IT Department's Story Photo #1178216
IT Department's Story Photo #1178217
問題
One of the founders of the company I work at accidentally left his MacBook outside, and it was attacked by his sprinkler system.
修理
There was some corrosion on the mainboard that had to be cleaned off, and the I/O Board and I/O Ribbon Cable had to be replaced, due to them being fried. But after replacin . . .
ユーザのアバター
問題
the battery app report information suggested that the part needed replacement to optimise.
修理
i've done several battery/screen replacements on iPhones.
opening the phone case took longer than expected. i found using my iSclack and the stabiliser attachment was a better fit than the single suction cup p . . .
ユーザのアバター
問題
The silence from the MacBook AIr was deafening and my client could no longer stand it!
修理
The repair went very quietly... and after the last screw was restored and thw power button pressed, that familiar startup sound came loud and clear!
アドバイス
No enlightenment, however, I do recommend following the steps and . . .
ユーザのアバター
問題
A friends MacBook Air had been for a drink and no longer powered on.
修理
Simple, with the right tools, attention to detail, patience and the correct guidance. We were lucky the IO board was the only part damaged by liquid. We also replaced the flex cable which had a red dot underneath (assume this is a l . . .
ユーザのアバター
問題
Not turning on after coffee spilt over.
修理
I thought the problem was on the I/O because the coffee got spilled over the charging area.
アドバイス
It is more probably that the logic board.
ユーザのアバター
問題
The output and input audio not working
修理
I fixed the problem replacing the I/O board and the I/O Board Cable
アドバイス
You should have patience to replace anything in Apple devices, is very difficult to remove all small flats correctly.
さらに表示する
