メインコンテンツにスキップ
はじめに
How to on how to replace the circuit board on a wireless charger.
パーツ
パーツは指定されていません。
  1. Remove the padding by using a flat tool to remove adhesive and pry padding off of device.  Be careful not to rip or tear. Remove the padding by using a flat tool to remove adhesive and pry padding off of device.  Be careful not to rip or tear.
    • Remove the padding by using a flat tool to remove adhesive and pry padding off of device. Be careful not to rip or tear.
  2. Remove (4) phillips head screws holding device together.  I used a #1.2mm phillips head screwdriver. Remove (4) phillips head screws holding device together.  I used a #1.2mm phillips head screwdriver.
    • Remove (4) phillips head screws holding device together. I used a #1.2mm phillips head screwdriver.
  3. Gently pry bottom cover off of device.  This will expose the circuit board. Gently pry top cover off device.  This will expose the charging unit of the device.
    • Gently pry bottom cover off of device. This will expose the circuit board.
    • Gently pry top cover off device. This will expose the charging unit of the device.
  4. There are two clips holding the circuit board in.  Using a flat surfaced tool pry on one clip until the circuit board pops up and then you can pull board out. The charging device is soldered to the board so be aware and careful not to break the solder or wire to device.
    • There are two clips holding the circuit board in. Using a flat surfaced tool pry on one clip until the circuit board pops up and then you can pull board out.
    • The charging device is soldered to the board so be aware and careful not to break the solder or wire to device.
  5. The charging unit is held on to the top of the device by adhesive.  Simply use a prying tool with a flat surface to gently pry away from adhesive.
    • The charging unit is held on to the top of the device by adhesive. Simply use a prying tool with a flat surface to gently pry away from adhesive.
  6. Once circuit board and charging unit have been removed you can replace with a new one.  Don't forget the adhesive tape.  Use reverse order!
    • Once circuit board and charging unit have been removed you can replace with a new one. Don't forget the adhesive tape. Use reverse order!
    • Note: There may be soldering involved if you only want to replace board and not charging unit.
終わりに
3 の人々がこのガイドを完成させました。
Bill
メンバー登録日: 2014年09月17日
818 ポイント
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 1,440
