はじめに
Not getting the speed and memory out of your tablet that you would like? Is there a bad connection between the motherboard and the digitizer, which may cause a black screen? If so, use this guide to replace the motherboard on the device. Be sure not to lose the screws once you remove the motherboard. There are a total of three screws that fix the motherboard onto the digitizer.
必要な工具と部品
Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
Continue around the entire device until all of the clips have been released.
Insert the flat side of the standard spudger underneath the battery and use a prying action to loosen the glue holding it to the digitizer.
Do this all around the battery until it comes off.
Loosen the edges of the black tape covering the camera using the heavy-duty spudger.
Use the freed edges of the tape to gently remove the camera assembly from its plastic housing.
Remove the three 2.2mm Phillips head screws using a screwdriver to loosen the motherboard from the shell.
