はじめに
The iRobot Braava 375t is a floor mopping and sweeping cleaning robot. The motherboard allows for everything in the device to be connected together. This article shows you how to replace the motherboard, which may be needed if the device doesn't turn on, even after replacing the battery.
必要な工具と部品
Flip device over.
Remove the cleaning cloth compartment on the bottom to access screws.
Disconnect the rest of the wires and remove all screws that are attached to the motherboard.
To remove the wires, disconnect the plastic pins in a similar fashion to the ones in the Battery Replacement guide.
ある他の人がこのガイドを完成しました。
