はじめに
The plastic part on the top of the iPod.
必要な工具と部品
この手順で使用する道具:Jimmy$7.95
Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
12 の人々がこのガイドを完成させました。
