はじめに
Face ID Not Working 'Move iPhone a Little Lower/Higher' is usually caused by damage of the dot projector and the problem is confirmed to be almost unrepairable. However, there is finally a solution to fix the problem.
ビデオの概要
Go to Settings > Face ID & Passcode > Set Up Face ID. When trying to setup Face ID on the iPhone, we get the message 'move iPhone a little lower/higher' .
Start the Camera app and select Portrait in the bottom bar. Switch to the front camera. When the camera detects a person's face, the name of the lighting effect ‘Natural Light’ stays the same. The pop-up notification keeps saying ‘Move farther away’.
Normally, when Portrait mode is ready, the name of the lighting effect ‘Natural Light’ should turn yellow.
Judging by this, the dot projector or relevant circuits of the dot projector might have malfunctioned.
Take apart the phone and remove the display assembly. We can see that the dot projector has been water damaged and the crystal on the dot projector is broken.
Pull the battery adhesive strips out. Take out the front camera assembly.
Connect the dot projector flex cable with the repair programmer. Click ‘Check’. Results: Fusing.
Judging by this, the dot projector flex cable has been damaged. We need to burn data of the original dot projector flex cable onto a new dot projector flex cable and then replace the broken crystal with a good one.
Cut off bracket securing the infrared camera and the dot projector with Cutting Nipper. Then place the front camera, the dot projector and the infrared camera in corresponding slots of the heating platform.
Heat with the Heating Platform at 110℃. Once the adhesive has been softened, take down the dot projector flex cable carefully.
Put the dot projector into the matching rubber mold. Heat with the Soldering Iron at 365℃. Separate the crystal from the flex cable carefully with the blade.
Now we need to burn data of the original dot projector flex cable onto a new dot projector flex cable.
Connect the original dot projector flex cable with the repair programmer. Click ‘Read’ to read data of the original dot projector flex cable. Then click ‘Save’ to save data of the original dot projector flex cable. Once done, disconnect the original dot projector flex cable.
Connect a new dot projector flex cable with the repair programmer. Click ‘Open’. Then click ‘Selected’. Click ‘Burn’ to burn the saved data onto the new dot projector flex cable. Once done, disconnect the new dot projector flex cable.
Grind the MOSFET here with a grinding tool. Then heat with Hot Air Gun to take down the dot projector module. Continue heating with the Hot Air Gun. Clean residual parts of the MOSFET with tweezers.
Continue to apply some medium-temp solder paste to the bonding pad. Tin the bonding pad with Soldering Iron. Here we need 0.02mm Enameled Copper Wire. Heat with Soldering Iron. Connect Pin 2 and Pin 3 of the MOSFET with the wire.
Turn the dot projector module over. Clean residual adhesive on the module with the sculpture knife. Then clean with Solder Wick thoroughly. Clean with PCB Cleaner afterwards.
Get the BGA reballing stencil in the right position. Apply some medium-temp solder paste. Heat with Hot Air Gun to get the dot projector module reballed.
Attach the new dot projector flex cable to the PCB Holder. Apply some paste flux to the new dot projector flex cable. Get the dot projector module in the right position. Solder with Hot Air Gun.
Cool for 2 minutes. Connect the new dot projector flex cable with the repair programmer. Click ‘Check’. Results: Normal. The infrared light emitted from the projector is also normal.
Apply some glue to the dot projector module. Get a known-good crystal in the right position.
Apply double-sided adhesive tape on the backside of the front camera. Adhere the dot projector flex cable to the right position.
Warning: the double-sided adhesive tape used here is for test. We need to glue the dot projector module onto the flex cable after fault clearance.
Now we can assemble the phone and test. Go to Settings > Face ID & Passcode > Set Up Face ID. Face ID can be setup successfully. The phone can be unlocked with Face ID this time.
- Face ID Teardown - Why Face ID Not Working After Repair
- How to Fix iPhone X Face ID Not Available
- How to Fix iPhone X Face ID Not Working 'Move iPhone a Little Lower/Higher'
- How to Fix iPhone X Face ID Not Working After Screen Replacement
- How To Restore True Tone After Screen Replacement On iPhone XS
- How to Fix iPhone 7/7P Home Button Not Working
- How to Upgrade iPhone 7 Plus Storage/Memory To 256 GB
- How To Fix iPhone 11 Pro Max Face ID Not Available - Motherboard Repair
- iPhone 8 Plus Back Glass Replacement
- iPhone 11 Pro Teardown
- Fix iPhone 8/8P/X Ambient Light Sensor Failure After Screen Replacement
- 100% Fix Non-Genuine Battery Warning / Important Battery Message On iPhone XS And Above
- iPhone 8 Broken Screen Glass Only Repair
- How To Fix iPhone 8 Stuck on Apple Logo
- iPhone 11 Series Non-Genuine Screen Warning/Important Display Message - 100% Fix
