メインコンテンツにスキップ
iPhone 11 Lightning端子アセンブリの交換
必要な工具と部品
ビデオインストラクション
終わりに
部品交換後の組み立ては、これらの手順を逆に実行してください。
40 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
3人の作成者と共同で作成されました。
Arty
メンバー登録日: 10/27/19
24,481 ポイント
92のガイドは作成済み
14 件のコメント
I would rather have a picture and written step by step, he doesn’t say some parts what is called
Dulce Vidal - 返信
Me too. I would appreciate knowing the size and type of all screws and standoffs and where they go.
I most likely mixed up a few of them and now the screen stays black.
Kim Mace -
First, DISCONNECT the battery before ANY connections, and the battery should be the last thing you re-connect. And you DO NOT need to remove the logic board.
Gregg Stanley - 返信
Just completed this repair. Wow it’s tricky but as echoed above, I would try and disconnect battery first although design of the iPhone 11 makes it very difficult to do this. Also, definitely don’t remove logic board and you don’t have to remove the battery either. Removing battery possibly makes it very slightly easier but if you take your time it’s not necessary. Good luck
richarddillon - 返信
IS not there a problem with at chip on the charging flex, that causes warnings and or re-boots I have been reading about somewhere?I mean, fitting it is easy enough, but APPPPle keeps annoying customers trying to stop them going to independent shops or doing repairs themselves!
JoeBlog - 返信
コメントを追加
統計データ:
過去 24時間: 50
過去 7 日: 291
過去 30 日: 1,360
今までの合計 53,978
