はじめに
This is the guide for replacing the face buttons on the iNNEXT N64 Classic Controller.
Before you begin this repair, make sure the controller is disconnected from the console.
必要な工具と部品
Turn the controller face down.
Use a Phillips #00 screwdriver to remove the eight screws on the back of the controller.
To remove the shoulder buttons, lift the buttons labelled with "L" and "R" upwards and out of the controller. There should not be any resistance coming out.
Use a Phillips screwdriver to remove the 6 screws securing the joystick assembly to the top of the controller.
Gently lift the control panel and joystick assembly from the top cover of the controller.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
