メインコンテンツにスキップ
iNNEXT N64 Classic Controller Face Buttons Replacement
必要な工具と部品
  1. iNNEXT N64 Classic Controller Face Buttons Replacement, Bottom Case: 手順 1、 2の画像 1 iNNEXT N64 Classic Controller Face Buttons Replacement, Bottom Case: 手順 1、 2の画像 2
    • Turn the controller face down.
    • Use a Phillips #00 screwdriver to remove the eight screws on the back of the controller.
  2. iNNEXT N64 Classic Controller Face Buttons Replacement: 手順 2、 1の画像 1
    • Insert an opening tool into the seam between the top and bottom case.
    • Work your way around edge of the controller to release the tabs connecting the top and bottom of the controller.
    • Remove the bottom case from the controller.
  3. iNNEXT N64 Classic Controller Face Buttons Replacement, Shoulder Buttons: 手順 3、 2の画像 1 iNNEXT N64 Classic Controller Face Buttons Replacement, Shoulder Buttons: 手順 3、 2の画像 2
    • To remove the shoulder buttons, lift the buttons labelled with "L" and "R" upwards and out of the controller. There should not be any resistance coming out.
    • To add the new buttons, put the top notch of the shoulder buttons into the hole right above the control circuit. There should not be any resistance going in. Once done, you can put the back of the controller back on
  4. iNNEXT N64 Classic Controller Face Buttons Replacement, Face Buttons: 手順 4、 2の画像 1 iNNEXT N64 Classic Controller Face Buttons Replacement, Face Buttons: 手順 4、 2の画像 2
    • Use a Phillips screwdriver to remove the 6 screws securing the joystick assembly to the top of the controller.
    • Gently lift the control panel and joystick assembly from the top cover of the controller.
  5. iNNEXT N64 Classic Controller Face Buttons Replacement: 手順 5、 1の画像 1
    • Remove the silicone button gaskets.
  6. iNNEXT N64 Classic Controller Face Buttons Replacement: 手順 6、 1の画像 1
    • Remove the old buttons by either pulling them out or pushing lightly from the front of the top case.
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
作成者
2人の作成者と共同で作成されました。
Khaymare commock
メンバー登録日: 10/24/24
265 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 3-4, Santin Fall 2024 UMass Dartmouth, Team 3-4, Santin Fall 2024人のメンバー
UMASSD-SANTIN-F24S3G4
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 96
