はじめに
Use this guide to replace a faulty Bluetooth Board.
必要な工具と部品
この手順で使用する道具:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Disconnect the Bluetooth cable by pulling its connector away from the socket on the Bluetooth board.
5 の人々がこのガイドを完成させました。
