はじめに
This guide will help you replace the hard drive.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx screws
Four 25 mm T8 Torx screws
Disconnect the LCD temperature sensor by pulling the connector straight out of its socket on the logic board.
410 の人々がこのガイドを完成させました。
46 件のコメント
Thank you Brittany for putting together an awesome guide! I was able to swap in a leftover MBA SSD into my 2007 iMac before gifting it to my father-in-law. This iMac was showing its age with Lion installed, mostly due to 2 GB of RAM and a so-so magnetic drive. I was hesitant to gift a hand-me-down with little usable life. Not anymore! I have no doubt that the 5GB of RAM and a super fast SSD breathed another 5+ years of enjoyment into this iMac. Reuse beats recycling! Thank you!
FYI - The iFixit store links for the Torx screwdriver incorrectly displays the security Torx drivers. I had my own set of regular Torx drivers and competed this successfully. I did not find the security (center post) variant of the Torx screwhead anywhere in my iMac.
Security Torx drivers work on both regular Torx and security Torx bits, so we sell the security drivers to keep people from having to buy two tools.
Excellent guide. The entire process took less than 90 minutes and I was not in a hurry. Everybody told me that the iMacs were designed to be "user-proof" and had to be worked on by qualified technicians. What do they know? Now my computer is back up and running with a 1TB drive and it cost less than $150 - even with shipping costs factored in. Great job guys!!!
The guide was extremely helpful, however, there are a few things that I wanted to mention that might add to the guide:
* Since my work surface was large enough to allow the bezel to sit on a flat surface while working on the CPU, I did not need to disconnect the microphone cable, thus I wasn't required to remove the tape from the plug.
* The iMac I fixed was running for over 4 years, so there was a lot of dust around the fan and stuck to the inside of the bezel. This surprised me. Someone might want to keep a small vacuum handy, or get a can of air. Be warned: This dust will require you to clean the LCD. No getting around it.
* Since I have big fingers, I was finding it almost impossible to reconnect the LCD cable that is underneath the power inverter logic board. So I found it much easier to remove the four screws on that small logic board, lift it up, plug the cable back into the bottom, and reattach the board. Otherwise I would have spent a long time trying to plug the cable.
Thanks again!
