メインコンテンツにスキップ
iMac Intel 21.5" Retina 4K Display (2017) Display Assembly Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. iMac Intel 21.5" Retina 4K Display (2017) Display Assembly Replacement, Display Assembly Separation: 手順 1、 2の画像 1 iMac Intel 21.5" Retina 4K Display (2017) Display Assembly Replacement, Display Assembly Separation: 手順 1、 2の画像 2
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  2. iMac Intel 21.5" Retina 4K Display (2017) Display Assembly Replacement: 手順 2、 3の画像 1 iMac Intel 21.5" Retina 4K Display (2017) Display Assembly Replacement: 手順 2、 3の画像 2 iMac Intel 21.5" Retina 4K Display (2017) Display Assembly Replacement: 手順 2、 3の画像 3
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
  3. iMac Intel 21.5" Retina 4K Display (2017) Display Assembly Replacement: 手順 3、 3の画像 1 iMac Intel 21.5" Retina 4K Display (2017) Display Assembly Replacement: 手順 3、 3の画像 2 iMac Intel 21.5" Retina 4K Display (2017) Display Assembly Replacement: 手順 3、 3の画像 3
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
終わりに
作成者
1人の作成者と共同作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
196,587 ポイント
416のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 8
今までの合計 169
