メインコンテンツにスキップ
iMac Intel 21.5" EMC 2428 光学ドライブの交換
必要な工具と部品
  1. iMac Intel 21.5" EMC 2428 光学ドライブの交換, ガラスパネル: 手順 1、 2の画像 1 iMac Intel 21.5" EMC 2428 光学ドライブの交換, ガラスパネル: 手順 1、 2の画像 2
    この手順で使用する道具:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    購入する
    • 作業を始める前に、iMacの電源を切り、画像のように本体を倒して、柔らかい表面上に載せてください。
    • ガラスパネルの上部コーナーの2箇所に吸盤カップを取り付けます。
    • iFixitが販売している吸盤カップを取り付けるには、まず吸盤カップの持ち手ハンドルをガラスパネルの表面に対して水平になるように上げてください。ガラスに吸盤カップを軽く装着して、もう一方のハンドルも平行になるように上げてください。
    • 吸盤カップがうまく装着しない場合は、ガラスパネルと吸盤カップを中性洗剤などで綺麗に拭き取ってください。
    Very easy to lift the glass out. Don't jerk too hard.
    kctipton - 返信
    Another comment on DATA & LCD Temp. Sensor cables: I had to remove the vertical sync, and the backlight cable, however, if you have an assistant or/can carefully rotate the screen clockwise/and then have it held up about 5" to 6" at a slight angle, you do not need to remove LCD data cable or LCD thermal cable, however - IMPORTANT: you must have a second pair of hands/or way to securely prop up the LCD. Also, don't rotate too much, since then you will pull out LCD data cable, and it renders the whole exercise moot, or can damage the cable or connector.
    MaximBorzov - 返信
    You don't need suction cups. The screen, held by magnets, can simply be pried off using a very thin blade such as a screw driver and fingers.
    Deepsurvival - 返信
    That's a bad idea. using a metal tool to pry off glass is likely to end with an expensive broken front glass.
    Suction cups are common. Find a couple and do it the safe way. I use some cheap ones that came with iPhone repair kit.
    max damage -
    No need for suction cups, I just stuck my nails (short like guys usually have) between the top part of the screen and body, and it came off easily. I've never done it before, so it seems to be very easy.
    Nikolas Lintulaakso - 返信
    Nails worked for me too
    Rob Dale - 返信
    Just completed the replacement of the optical drive with an SSD using an OWC Data Doubler kit. Attempted to remove the optical drive without disconnecting any cables but found it a bit fiddly to orient the screen for good access. I bit the bullet and disconnected them and found the process less daunting than I imagined. Reconnecting them was similarly straightforward if you're careful.
    Tip: you can skip the step for removing the optical drive thermal sensor connector from the motherboard. Still need to remove the sensor from the optical drive but you can leave that hanging and reattach it to the SSD later.
    osienna - 返信
    I use Garmin GPS suction cup. Work very well
    jc3Dcx - 返信
    I’ve just successfully installed a 1TB SSD in place of my optical drive thanks to the information here- thank you to everyone who has contributed!
    3 comments- the procedure described here seems to vary between HD replacement and dual HD/optical drive replacement. This can be confusing at times.
    Expect there to be minor differences between the layout described and what you find when you open up your iMac. There are also, surprisingly, differences between the HD enclosure description, and the article provided by ifixit.
    I was able to replace the DVD/HD enclosure single-handedly without fully removing the LCD, or deconnecting any of the cables (steps 5-11). It’s a bit cramped, and fiddly, but I was not happy removing any of the cables despite watching videos, etc., since they all seemed to involve applying more force than I was comfortable with. A more detailed description of how to release them might have helped, but even here, there may be minor variations even within the 2389 model.
    Good luck!
    ivan birks - 返信
    I did it several times with one suction cup at the end of a kitchen brush. Once with the blade of a swiss army knive, also ok. And i’m pretty sure it works with fingernails too
    Tai - 返信
    Fingernails are all you need to free the glass from its magnetic hold. If you don’t have them, slip something thin and plastic, like a spudger, at a top corner.
    Max Powers - 返信
    Minha dúvida é a seguinte: após o técnico trocar o HD do meu iMac de 21,5 polegadas, a câmera parou de funcionar. Seria por causa da troca do HD? Tem solução?
    Claudio - 返信
    Creio que o cabo da camera não foi plugado ou deu mau contato… ou até danificado.
    glecyo@gmail.com
    glecyo medeiros -
    I can’t get my glass to budge. I’m replacing a cracked one and now it’s about to shatter.
    jamboxmitchell - 返信
    I know that I'm replying really late but I advise to use clear tape over any cracks so the cracks don't get bigger
    Jace Holmes -
    Check for chips in the glass BEFORE you do this step. If there is a chip when you pull up with the suction cups you will wind up with a jagged mess. If you do have a chip I would advise covering the screen near the chip with clear tape of some kind before lifting out. Mine shattered right at the chip and the resulting glass dust cloud got all over. My solution was buying a new glass screen.
    BCam - 返信
  2. iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 2、 2の画像 1 iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 2、 2の画像 2
    • ゆっくりとガラスパネルをLCD表面に垂直になるように持ち上げて、スチール製のマウントピン
    • ガラスパネルをiMacの底側端から引き抜き、丁寧に脇に置いてください。
    • 再組み立ての際には、ガラスパネルの内側やLCD表面を綺麗に拭いてください。デバイスの電源を入れると、ほこりや指紋が内部に閉じ込められ、視界が遮られてしまうことがあります。
    What's the best product to clean the face of the LCD?
    Steve Speirs - 返信
    Microfiber Cloth
    Leonardo Fournier -
    Try your best not touch it in the first place
    Brian -
    Wearing Nitrile or regular surgical gloves helps prevent finger prints if you accidentally touch the glass.
    amiller770 - 返信
    I use a Swiffer duster from above at the last moment before I let the magnets grab the glass cover. This has worked so well the last dozen or so times I’ve replaced a glass cover since I never have access to a “clean room” and don’t wear a “bunny suit”.
    Also, more dust will shed from your skin if you’ve just taken a shower, so I like to finish these repairs in the morning before a shower.
    gatortpk - 返信
  3. iMac Intel 21.5" EMC 2428 光学ドライブの交換, ディスプレイ: 手順 3、 3の画像 1 iMac Intel 21.5" EMC 2428 光学ドライブの交換, ディスプレイ: 手順 3、 3の画像 2 iMac Intel 21.5" EMC 2428 光学ドライブの交換, ディスプレイ: 手順 3、 3の画像 3
    • アウターケースにディスプレイを固定している8 mm T10トルクスネジを8本外します。
    • 最後2枚の画像はディスプレイ両サイドの詳細な様子です。
    The metal near the screws is VERY magnetic. Honestly, the hardest and by far most frustrating step was trying to put these screws back in.
    seancourtney - 返信
    I ran into the same problem - easily the most frustrating part of this process. To help deal with it, I took a drinking straw, cut it to be about 2 inches long, and used it as a chute to guide the screw to the hole. Dropping the screw down the straw, it'd still stick to the side due to the magnets, but using my screwdriver, it was easy to push the screw down to where it needed to go, and the straw kept the screw from being pulled out of place by the magnets.
    josh -
    +1 for the straw tip. Worked a treat!
    osienna - 返信
    Hmm… yes, the magnets sucks - literally. But if you use a normal screwdriver or a bit, the screwdriver tip or the bit can be “loaded” by the magnets too. Just move the screwdriver (or bit) over one of the magnets and then “plug” the screw onto the screwdriver’s tip (or bit). It will be held by magnetic force. Just enough to move the screw vertically and very slowly into the whole.
    There are some special screwdriver on the market with “claws” to hold screws, but they are hard to find/to buy and expensive. I sometimes use superglue (a LITTLE) to temporary fasten the screw at the screwdrivers tip. This technique can be used with destroyed screw heads too to optimize adhesion.
    Udo - 返信
    Les vis sont inévitablement aimantées
    Gui - 返信
    Replacing these screws was like playing the most difficult game of “Operation” imaginable. I wish I’d seen the tip about using a straw before I started playing!
    Bret Mogilefsky - 返信
  4. iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 4、 1の画像 1
    • アウターケースからディスプレイの上部端をわずかに持ち上げます。
    • あまり高く持ち上げすぎないでください。ディスプレイとロジックボードには数本のケーブルが接続されたままです。ケーブルが付いたままディスプレイアセンブリをひねったり、引っ張るとiMac本体にダメージを与えてしまいます。
    You can use one hand to hold the edge up while reaching with the other hand to disconnect cables. You may want to have a prop handy (like a small book) or an extra person to hold the edge up while you disconnect cables.
    kctipton - 返信
    Use the teardown guide for your iMac to familiarise yourself with the layout of everything before you dive in. I was able to get an idea of how much clearance there was once the display is unfixed from the frame, where the optical drive was relative to the base etc
    osienna - 返信
    The harddisk can be removed WITHOUT the next steps. The opening angle of the partially lifted LCD display gives enough room to untighten the two Torx T9 screws of the hard disk bracket, to unplug the two SATA connectors and to carefully lift out the harddisk. There is absolutely no need to dismantle the whole thing.
    All you need is a screwdriver which fits into the room. I’ve used the “Pro Tech Toolkit” from iFixit. The screwdriver with Torx T9 bit fits perfectly.
    The other “tool” you need is either someone who holds the LCD plate or the inner leftover of a kitchenroll, a scrunched paper, a small towel or similar which has to be stuffed between the logic boards and the LCD plate to keep the LCD at its lifted place (careful! don’t unplug any of the cables).
    I’ve opened and changed the harddisks of those 21,5 iMacs a dozen times with the help of the “Pro Tech Toolkit” and a kitchen roll.
    Udo - 返信
    If i want to replace the HD with a SSD, can i still skip the next steps? I think i can’t because i need to change the termal censor, but i would like an other opinion please.
    Danois -
    “Kitchen Roll” - paper towel core.
    kyoder11 -
    You can absolutely replace the drive without removing any cables. It's a little tight, you need your torx driver to be short enough to fit in the limited space. Be careful not to put any pressure on the cables (the one nearest the front is a good guide of how much space you have to play with). It's helpful to have another set of hands to hold it up while you remove the drive, but I just did it by holding the display up with one hand and it wasn't that hard to remove and replace the drive.
    I wouldn't install any thermal sensor, just use something like Macs Fan Control (free) to adjust the fans so they don't race out of control.
    maccentric -
    Hia,
    thx to IFIXIT and 20+ years of computer repair and building experience (all PC) there was no problem at all to remove a 500 Gb HDD from a mid 2011 iMac and replace it with an 500 Gb SSD Drive (with help from Comtec EDV, where i bought the upgrade kit).
    Skip the steps where people are advised to remove the display. Due to my experience it is def better to leave cables and plugs where they are. I lifted the display 12 cm and fixed this position w/ one pencil in each front corner of the case where the other end of the pencil sticked in ascrew hole of the display-frame. Very easy to operate afterwards! No probs w/ the screws of the hdd-frame.
    Some care-taking of static electricity is advised - wear a wrist cable. And don’t forget to press start button after having removed power chord. I had an Android Tablet on the right side, where i could watch these ifixit pages :-)
    thx to IFIXIT!
    w/ regards from cantbtroo from Berlin
    Hans- Peter - 返信
    Thank you ifixit for the guide. Like so many others I jumped from step 4 to step 10 and left all the cables intact. Felt much safer doing so. Papertowel cores secured the LCD to higher position. There was enough room to remove the old HDD and replace it with a SSD drive.
    Cheers!
    Aapo Kaivosoja - 返信
    I also was able to proceed with rest of instructions, after skillping steps 4-10, just have to be very gentle, i think it would help to have a second set of hands to hold screen above while other hands are uninstalling and installing hard drive, but i was able to do it on my own
    jacob d - 返信
    If you have trouble lifting the LCD or accessing the connectors, check if you have removed the right screws. There are a lot of identical Torx screws that are accessible without removing the LCD that have nothing to do with the screen, I learnt that by nearly breaking mine xD
    Luther - 返信
  5. iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 5、 2の画像 1 iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 5、 2の画像 2
    • iMacの左上隅付近にあるLEDドライバボードのソケットから垂直同期ケーブルコネクタを引き抜きます。
    Tried doing this on my iMac, but this cable would not come out for love or money. No matter what I did, I could not unplug this cable. My iMac is the same 21inch 2011 as this one. Any advice would be greatly appreciated.
    louis.barr - 返信
    use a little poker type thing in your right hand to push on the 2 holes that are on top of the plug and wiggle it out with your other hand,
    Nicholas - 返信
    I was tempted to forgo steps 4-10 but found the inside of the case to be very dusty and decided to do the full disassemble. I struggled getting this vertical sync cable connector out. The trick that worked for me was to prop the display up using a pair of toilet paper tubes then using the fingernails of both thumbs, one on each side of the connector and it came out easily.
    Anthony Zimmerman - 返信
    Great idea of using toilet paper tubes to prop up the LCD! Thanks.
    jim - 返信
  6. iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 6、 2の画像 1 iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 6、 2の画像 2
    • LEDドライバボードから、LEDバックライトの電源ケーブルの接続を外すため、ディスプレイをアウターケースから回転させて取り出します。
    • コネクタをソケットから引き離しながら(iMacの下端に向かって)ロック機構を押し下げ、LEDバックライト電源ケーブルの接続を外します。
    Slip a thumbnail under the “front” (toward the top of the iMac) of the connector to release its clamp from the retaining ridge. Then push toward the “back” (bottom of iMac).
  7. iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 7、 3の画像 1 iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 7、 3の画像 2 iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 7、 3の画像 3
    • ディスプレイデータケーブルのロックに固定されたプラスチックのプルタブを掴み、上向きに回転させます。
    • ディスプレイデータケーブルを、ロジックボード上のソケットからまっすぐ引き抜きます。
    • ディスプレイデータケーブルを上向きに引き抜かないでください。このソケットは壊れやすいためです。ケーブルをロジックボードの表面と並行に引っ張ります。
    I am having a difficult time reattaching the LCD cable. A better description or any tips would be useful here.
    Ben Bauermeister - 返信
    Me too — ditto that.
    Roger Buttermore -
    https://eshop.macsales.com/item/OWC/DIDI... —> abt. 5:30 into the vid. Handle up to slide in, then flip it down to lock the connector in place.
    Roger Buttermore -
    The connector needs to be carefully pushed in parallel to the board with a surprising amount of pressure and the pull tab must be folded back. Not super fragile, but not strong either.
    Isaac Vande Zande - 返信
    I really wish that the fagility of this connector was mentioned in Step 10 or 11.. When i rotated the screen on step 11.. It pulled this connector out and now I can't get it back in.. I hate computers.. HA!
    Philip Nelson - 返信
    This is the most painful part of the whole event. Replacing this cable took me around 30 minutes !
    K. Efe Egilmez - 返信
    I have tried and tried to get this cable back in. How do I know if I have messed it up?
    Christopher Teer - 返信
    Mine seems to be…upside down? Looks like the little flappy lock thing is on the bottom as opposed to it being in top as pictured?
    jinnifer douglass - 返信
    I agree with everybody that this is the critical step in this fix. Removing it is not that difficult, the description is quite accurate, but I would highlight that the “rotate” part of the step could be detailed: the black plastic tab is attached to the metal lock (golden colored) , which should rotate into the direction of the cable almost 180 degrees to unlock the connector. After doing this you can pull the cable out of the connector, PARALLEL to the board and away from the connector. It travels a very short distance to disconnect. After going through the rest of the steps to remove the display, take some time to examine closely the connector and understand what you have to do to reconnect it on assembly. It helps to fully visualize beforehand, since on reassembly it is difficult to see properly.
    Fernando Walker - 返信
    Magnifying glasses are needed for this step. Carefully study the cable and how it attaches to the connector. Take a few pictures to help. This is the most difficult step.
    Norman Staples - 返信
  8. iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 8、 2の画像 1 iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 8、 2の画像 2
    • ロジックボード上のソケットからLCD温度センサーのケーブルコネクタの接続を外します。
    When putting the display down on the table, be careful not to kink the flat ribbon cable.
    frank - 返信
    The replacement hard drive I used doesn't even appear to spin up and the Time Capsule restore process doesn't show it as available. It just stays at Searching for disks and never finds it.
    JRBv3 - 返信
    I had to use Disk Utility to partition the drive and then it showed fine. Rookie mistake.
    JRBv3 -
    I managed to damage the LCD thermal sensor socket in the logic board. Now the connector won’t stay in place. I know the missing thermal sensor should cause the fans to spin up (they do spin up after a while), but the screen is blank.
    I connected an external monitor and it works fine, so it doesn’t seem to be a graphics or logic board issue. I also replaced the LED driver board with one from a working iMac, to no effect.
    Can the missing thermal sensor be causing this?
    Rodrigo da Rosa Cesconeto - 返信
    Having the same problem. Black screen, works fine with external display.
    Passerby -
  9. iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 9、 1の画像 1
    • 慎重にディスプレイをiMac上部端に向けて引き抜き、アウターケースから持ち上げます。ケーブルが巻き込まれないようご注意ください。
    Btw, I was pretty safe (& content) with two suction cups - i bought 3 for less than 7 Euros. They were a good help for a glass that hasn’t been removed since 2011. But i am sure fingernails will do a good job, too (of course not mine, cos i have short ones).
    At the end of the job it was even possoible to clean the fan that sucks cool air into the iMac (w/ a paintbrush and a controllable vaccuum cleaner). After that, it’s also a good opportunity to clean the air inlet that is part of the aluminium case (behind the stand - it’s always dusty).
    w/ regards from cantbtroo, Berlin
    Hans- Peter - 返信
  10. iMac Intel 21.5" EMC 2428 光学ドライブの交換, 光学ドライブ: 手順 10、 1の画像 1
    • ここから、デバイス本体を裏返して、ベース部分を上向きにすると作業がしやすくなります。
    • 次の4本のネジを外します。
    • 9.3 mm T10 トルクスネジ(大)ー1本
    • 9.3 mm T10トルクスサイズ(通常サイズ)ー3本
    In my case the red screw was on the lower left side near the power-data cable!
    sefw4t2efwef - 返信
    Same here. There are different versions delivered
    Tai - 返信
  11. iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 11、 2の画像 1 iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 11、 2の画像 2
    • ロジックボード上のソケットから光学ドライブ温度センサのコネクタをまっすぐ引き抜きます。上向きに引くのではなく、ボードに並行になるように抜いてください。
    No need to remove the thermal sensor connector from the motherboard - refer to Step 17 to remove the sensor from the optical drive instead
    osienna - 返信
    The thermal sensor connector shown in the red box is the one for the hard drive, not the optical drive. The optical drive sensor attaches to motherboard near bottom left of optical drive fan.
    Reiner Friedel - 返信
    The guide was correct in my case that this is the Optical Drive sensor. The board has “ODD Temp” written on it. Original HD has it’s own built in temperature sensor without a separate cable to the Motherboard, which is why OWC sells a special “In-line Thermal Sensor” SATA cable with a Temp. sensor that attaches to any new hard drive itself.
    amiller770 - 返信
    When I was removing the optical drive cable sensor the connector came loose from the board. Is there any way to repair this?
    Paula McCaulla - 返信
  12. iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 12、 2の画像 1 iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 12、 2の画像 2
    • 光学ドライブ内側の端を持ち上げて、ロジックボードに付いているGPUフレームのコネクタを絡まないように外してください。
    • 光学ドライブをアウターケース右側に付いている固定ピンから慎重に引き抜き、光学ドライブケーブルの接続を外すためにスペースを確保します。
    • GPUヒートシンクの後ろから光学ドライブ温度センサのコネクタを取り外すには、光学ドライブの後ろを通してください。
    On the reassembly, I found threading the optical drive cable back under the GPU frame trying. Here’s some advice: Take some dental floss, form a loop, and feed that loop under the GPU frame. Put the cable into the loop of floss, tighten the loop, and pull the loop back through. This is much easier, faster, and far less frustrating.
    Albert Einsrein - 返信
  13. iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 13、 1の画像 1
    • 光学ドライブから光学ドライブのコネクタを引き抜いて、光学ドライブケーブルの接続を外します。
    • iMacから光学ドライブを取り出します。
    I have already installed the second SSD drive, but due to the size of the drive I need to change it with another SSHD 1 TB drive. Am I right that I have to follow the instructions up to Step 18? Because The SSD is already behind the optical drive, so what I need to do is remove it and install the new SSHD drive and put everything back again. Please confirm.
    Mohamed Kamal - 返信
    This was my only error on reassembly. The SATA cable must be under the black plastic prong. I did not want to pull to logic board again. I managed to bend the black plastic bits and get the cable in the right place.
    Terry Creasy - 返信
  14. iMac Intel 21.5" EMC 2428 光学ドライブの交換, 光学ドライブ: 手順 14、 2の画像 1 iMac Intel 21.5" EMC 2428 光学ドライブの交換, 光学ドライブ: 手順 14、 2の画像 2
    • 光学ドライブブラケットからEMIテープ全体を剥がす必要はありません。光学ドライブのボディにつけられた赤色でハイライトされた部分のみを剥がしてください。
    • 赤色でハイライトされたアルミテープ部分のみを剥がします。残りは黒い光学ドライブブラケットに装着したままにします。
  15. iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 15、 2の画像 1 iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 15、 2の画像 2
    • 光学ドライブの両側からT10トルクスネジを2本ずつ(計4本)外します。
  16. iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 16、 3の画像 1 iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 16、 3の画像 2 iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 16、 3の画像 3
    • 必要に応じて、スパッジャーの先端を使って光学ドライブの底につけられた光学ドライブブラケット用のスロットに押し込んで、ブラケットのタブを外します。
    • 光学ドライブブラケットを光学ドライブからわずかに回して外します。
    • 光学ドライブブラケットを光学ドライブのオープンエンドから引き離します。タブが引っ掛からないようにご注意ください。
  17. iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 17、 2の画像 1 iMac Intel 21.5" EMC 2428 光学ドライブの交換: 手順 17、 2の画像 2
    • スパッジャーの先端を使って、光学ドライブサーマルセンサを覆っているフォーム製テープの一部分を剥がします。
    • スパッジャーのフラットエンドを使って、サーマルセンサを光学ドライブに固定している接着剤を丁寧に剥がします。
    • 光学ドライブ内部にディスクや他の異物が詰まっている場合は、このガイドを参照して問題を解消しましょう。
    Can you (re)use this exact thermal sensor on the optical drive and attach it to a new SSD?
    Ali Mir - 返信
    @AliMir - yes, you can reattach the thermal sensor to the new SSD
    osienna - 返信
    Hello, I've broken the temperature sensor of the unit superdirve, where I can buy one?
    Angel Blasco - 返信
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
41 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
7人の作成者と共同で作成されました。
Walter Galan
694,692 ポイント
1,203のガイドは作成済み
4 件のコメント
Great How-to, except the how to find the replacement Optical Drive... Can't find the 2428 online anywhere. Any help with the part number before cracking the iMac apart would be greatly appreciated!
swav1971 - 返信
Great tutorial. Now if I wish to replace the Superdrive by an SSD (the Superdrive is dead), since the SATA port of the Superdrive is 3Gb/s only, can I keep the Superdrive cable for the SSD but swap it plug to the free SATA III port on the motherboard? Or do I need a new cable?
Thanks
Emilio Imparato - 返信
What kind of caddy do I need if I want to put an SSD in there? Is it 9.5mm or 12.7mm? Is any of it non-standard?
Stefan Monnier - 返信
Hi! 12mm for imacs and 9 to macbooks... but 9 fits too cuz the place in imac is bigger (also 12 on macbooks not fit)
glecyo medeiros -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 53
今までの合計 37,079
