はじめに
Use this guide to replace your display inverter.
必要な工具と部品
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the following three screws securing the inverter to the chassis:
Two 7.9 mm Phillips.
One 26 mm Phillips.
もう少しです!
終わりに
4 の人々がこのガイドを完成させました。
