はじめに
iMac not reading disks anymore? Use this guide to replace your optical drive.
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Remove the two 3.7 mm T6 Torx screws securing the optical drive connector board to the optical drive.
15 の人々がこのガイドを完成させました。
