メインコンテンツにスキップ
iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement
必要な工具と部品
  1. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, Bottom Plate: 手順 1、 1の画像 1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement: 手順 2、 1の画像 1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement: 手順 3、 1の画像 1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, Bottom Plate Housing: 手順 4、 2の画像 1 iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, Bottom Plate Housing: 手順 4、 2の画像 2
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement: 手順 5、 2の画像 1 iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement: 手順 5、 2の画像 2
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
  6. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, PRAM Battery: 手順 6、 2の画像 1 iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, PRAM Battery: 手順 6、 2の画像 2
終わりに
10 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Justin
メンバー登録日: 10/05/11
303 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 21-22, Maness Fall 2011 Cal Poly, Team 21-22, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S21G22
4 メンバー
13のガイドは作成済み
7 件のコメント
We are not allowed to use screwdrivers to pry open stuff. Unfortunately, that is exactly what we did in step 6 of Dissasembling the back up battery
David Hunter - 返信
Don't you need to replace the thermal paste?
adoug27 - 返信
Yes you do in the areas circled in orange. I'd also recommend changing the paste under the heatsink itself as that will probably be dried up.
yotoprules -
I love my very first Mac ever, it is still working. After a couple of time living with its amnesia (forgot time and what else…) I’ve decided to replace the battery. Thanks for this helpful article. It made it easy to me to replace the battery.
Roland Brezina - 返信
Good guide ! less than 20 minutes to change the battery, cleaning the interior included !!
SURIN Dominique - 返信
Any thoughts? I replaced the battery and reapplied the thermal grease. iMac still won’t turn on.
Jessica - 返信
Did you check voltage of the new battery? Should be 3.6v.
Otherwise it could be a logic board or PSU problem.
yotoprules -
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 34
過去 30 日: 116
今までの合計 11,492
