この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Use this guide to replace your iHome iP1's damaged or faulty 30-pin connector. This connector is located on the iPod/iPhone dock and is used to connect your Apple device to your iHome iP1.
必要な工具と部品
Rotate the iHome so that the speakers are facing you.
Disconnect the silver ribbon cable connected to the 30-pin connector (the middle one) by pulling it directly up.
ある他の人がこのガイドを完成しました。
4 件のコメント
Where can you buy a new pin connector?
shoreman19 - 返信
Where can I buy a new pin connector?
shoreman19 - 返信
