このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
The lower case can now be completely removed from the device!
この手順は未翻訳です。 翻訳を手伝う。
Turn the iHome 180 degrees and carefully pull up on speaker cases to pry them loose from the bottom case.
Pulling outwards on the sides of the Upper Casing can help loosen the assembly.
If it seems too difficult to remove, chances are that a screw is still attached. Make sure you've removed every screw listed before proceeding to this step.
Pull the back adapter cover off.
この手順は未翻訳です。 翻訳を手伝う。
Remove the four 6.4 mm Phillips #1 screws holding the adapter to the outer case.
Two 6.4 mm Phillips #1 screws near the center of the adapter. These screws have built in washers.
One 4.0 mm Phillips #1 screw near the center of the adapter.
The iPod adapter should now be separate from the upper casing.
2 の人々がこのガイドを完成させました。
