はじめに
This is where all of the power comes into the device. Learn how to replace it. Be careful while soldering!
必要な工具と部品
Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
Locate the three solder connections for the electrical port.
Desolder the connection points following the instructions included with your soldering kit as you remove the port.
ある他の人がこのガイドを完成しました。
