メインコンテンツにスキップ
dreamGEAR Quad Dock Pro Electrical Port Replacement
必要な工具と部品
  1. dreamGEAR Quad Dock Pro Electrical Port Replacement, Prerequisite Guide to Accessing Interior: 手順 1、 2の画像 1 dreamGEAR Quad Dock Pro Electrical Port Replacement, Prerequisite Guide to Accessing Interior: 手順 1、 2の画像 2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Electrical Port Replacement: 手順 2、 2の画像 1 dreamGEAR Quad Dock Pro Electrical Port Replacement: 手順 2、 2の画像 2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Electrical Port Replacement: 手順 3、 1の画像 1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Electrical Port Replacement, Mother Board: 手順 4、 2の画像 1 dreamGEAR Quad Dock Pro Electrical Port Replacement, Mother Board: 手順 4、 2の画像 2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Electrical Port Replacement: 手順 5、 1の画像 1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Electrical Port Replacement: 手順 6、 2の画像 1 dreamGEAR Quad Dock Pro Electrical Port Replacement: 手順 6、 2の画像 2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: 手順 7、 3の画像 1 dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: 手順 7、 3の画像 2 dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: 手順 7、 3の画像 3
    この手順で使用する道具:
    購入する
    • Locate the three solder connections for the electrical port.
    • Desolder the connection points following the instructions included with your soldering kit as you remove the port.
    • FIRE HAZARD! BURN DANGER! Follow all the safety precautions included with your soldering kit.
    • It is helpful to use a nylon or metal spudger or tweezers for the removal of this component, pieces of which are very hot.
    • You can follow iFixit's guide to soldering here.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jacob
メンバー登録日: 03/11/15
757 ポイント
6のガイドは作成済み
チーム
Colorado Springs, Team 4-4, Panko Spring 2015 Colorado Springs, Team 4-4, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S4G4
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 11
今までの合計 330
