メインコンテンツにスキップ
Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement
必要な工具と部品
  1. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement, Heater: 手順 1、 2の画像 1 Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement, Heater: 手順 1、 2の画像 2
    • Disconnect the power plug located on the back of the massage pillow.
    • Please do this step carefully in order to avoid electric shock.
  2. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 手順 2、 2の画像 1 Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 手順 2、 2の画像 2
    • Unzip the cover. You can locate the zipper at the back of the massage pillow.
    • Take out the pillow so that you can manage the heater completely.
  3. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 手順 3、 1の画像 1
    • Use a Phillips JIS #1 screwdriver to remove the screw at the center of the heater.
    • The screw is 8.0mm.
  4. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 手順 4、 2の画像 1 Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 手順 4、 2の画像 2
    • Remove the entire heater from the pillow.
    • You can see a green circuit board after removing the heater.
  5. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 手順 5、 1の画像 1
    • Using the Phillips JIS #1 screwdriver, remove the three screws circled in the picture.
    • All three screws are 8.0mm, which are the same size as the previous one. They are interchangeable.
  6. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 手順 6、 1の画像 1
    • Now you can take out the circuit board. There will be two wires attached to the circuit board.
    • If you prefer, you can clean the circuit board gently with dry tissues to remove the sticky lubricant.
  7. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 手順 7、 1の画像 1
    • Use the pry bar to separate the wire from the white main board.
    • Before prying, check if you removed the power plug from the outlet and the massage pillow.
  8. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 手順 8、 1の画像 1
    • Using your soldering station, remove the wires from the circuit board.
    • If you don't know how to solder, you can check out this guide: How To Solder and Desolder Connections
    • Soldering can be dangerous. Be cautious of high heat soldering tools.
    • Now, you can separate the circuit board completely to replace with a new heater.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Yuchen Li
メンバー登録日: 09/28/15
125 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 14-2, Green Fall 2015 Cal Poly, Team 14-2, Green Fall 2015人のメンバー
CPSU-GREEN-F15S14G2
4 メンバー
8のガイドは作成済み
2 件のコメント
Hi YuChen, nice work! Do you know from where I can find the switch for this heater? If you can tell me the part number, I can try looking it up on eBay. Thanks!
Abhishek Srivastava - 返信
YuChen, by any chance do you know where I can get the whole covering of this Shiatsu Massage Pillow. The fabric of mine has deteriorated and torn off. I have been trying to find one using Google search but was unable to find. Can you help, Thank you
gamesake2 - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 25
今までの合計 6,078
