メインコンテンツにスキップ
Zerodate T26 Side Button Sensors Replacement
必要な工具と部品
  1. Zerodate T26 Side Button Sensors Replacement, Scroll Wheel: 手順 1、 2の画像 1 Zerodate T26 Side Button Sensors Replacement, Scroll Wheel: 手順 1、 2の画像 2
    • Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
  2. Zerodate T26 Side Button Sensors Replacement: 手順 2、 2の画像 1 Zerodate T26 Side Button Sensors Replacement: 手順 2、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the adhesive pads using precision tweezers or the iFixit opening tool.
    • Adhesive pads are located on the bottom of the mouse.
  3. Zerodate T26 Side Button Sensors Replacement: 手順 3、 2の画像 1 Zerodate T26 Side Button Sensors Replacement: 手順 3、 2の画像 2
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws.
  4. Zerodate T26 Side Button Sensors Replacement: 手順 4、 2の画像 1 Zerodate T26 Side Button Sensors Replacement: 手順 4、 2の画像 2
    • Carefully pull the middle shell apart from the bottom plate.
    • The circuit board should then be visible and attached to the bottom plate.
  5. Zerodate T26 Side Button Sensors Replacement: 手順 5、 2の画像 1 Zerodate T26 Side Button Sensors Replacement: 手順 5、 2の画像 2
    • Remove the scroll wheel by pushing it to the right and pulling up.
  6. Zerodate T26 Side Button Sensors Replacement, Side Button Sensors: 手順 6、 3の画像 1 Zerodate T26 Side Button Sensors Replacement, Side Button Sensors: 手順 6、 3の画像 2 Zerodate T26 Side Button Sensors Replacement, Side Button Sensors: 手順 6、 3の画像 3
    • Take out the battery obstructing movement. This should now allow you to gently pull the circuit board up from the bottom of the mouse.
    • Please be very careful when pulling up the circuit board! Yanking it out could result in further damage to the mouse. Make sure you go slow and steady!
  7. Zerodate T26 Side Button Sensors Replacement: 手順 7、 1の画像 1
    • Carefully clean out any debris that might be obstructing the side buttons.
    • To replace the switches attached to the circuit board, carefully de-solder the two switches found here.
    • Please be sure to review safety guidelines and guided steps on soldering before attempting to remove any circuitry. In order to keep yourself safe and your mouse undamaged, please follow the guide found here to learn to properly solder.
終わりに
作成者
2人の作成者と共同で作成されました。
Janice Rullan
メンバー登録日: 03/13/23
662 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 2-3, Petersen Spring 2023 UMass Dartmouth, Team 2-3, Petersen Spring 2023人のメンバー
UMASSD-PETERSEN-S23S2G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 4
過去 30 日: 9
今までの合計 84
