メインコンテンツにスキップ
Zerodate T26 Main Clicker Replacement
必要な工具と部品
  1. Zerodate T26 Main Clicker Replacement, Scroll Wheel: 手順 1、 2の画像 1 Zerodate T26 Main Clicker Replacement, Scroll Wheel: 手順 1、 2の画像 2
    • Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
  2. Zerodate T26 Main Clicker Replacement: 手順 2、 2の画像 1 Zerodate T26 Main Clicker Replacement: 手順 2、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the adhesive pads using precision tweezers or the iFixit opening tool.
    • Adhesive pads are located on the bottom of the mouse.
  3. Zerodate T26 Main Clicker Replacement: 手順 3、 2の画像 1 Zerodate T26 Main Clicker Replacement: 手順 3、 2の画像 2
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws.
  4. Zerodate T26 Main Clicker Replacement: 手順 4、 2の画像 1 Zerodate T26 Main Clicker Replacement: 手順 4、 2の画像 2
    • Carefully pull the middle shell apart from the bottom plate.
    • The circuit board should then be visible and attached to the bottom plate.
  5. Zerodate T26 Main Clicker Replacement: 手順 5、 2の画像 1 Zerodate T26 Main Clicker Replacement: 手順 5、 2の画像 2
    • Remove the scroll wheel by pushing it to the right and pulling up.
  6. Zerodate T26 Main Clicker Replacement, Main Clicker: 手順 6、 1の画像 1
    • If the switches themselves are the issue, first dip a Q-tip into some isopropyl alcohol and rub it into and around the white switches. This should remove any dirt or debris that is impeding the operation of the switch.
    • The red switch seen in this image would otherwise be covered by the scroll wheel.
  7. Zerodate T26 Main Clicker Replacement: 手順 7、 1の画像 1
    • If the switches still do not work, then they need to be replaced. Mouse clicker switches can be purchased online, please refer to this soldering guide for the steps needed to remove and replace these switches.
    • Please be sure to review safety guidelines and guided steps on soldering before attempting to remove clicker switches.
終わりに
作成者
3人の作成者と共同で作成されました。
Janice Rullan
メンバー登録日: 03/13/23
662 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 2-3, Petersen Spring 2023 UMass Dartmouth, Team 2-3, Petersen Spring 2023人のメンバー
UMASSD-PETERSEN-S23S2G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 19
今までの合計 172
