メインコンテンツにスキップ
Zenbre SoundBank Z3 Speaker Grill Replacement
必要な工具と部品
  1. Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: 手順 1、 2の画像 1 Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: 手順 1、 2の画像 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Grill Replacement: 手順 2、 1の画像 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Grill Replacement: 手順 3、 2の画像 1 Zenbre SoundBank Z3 Speaker Grill Replacement: 手順 3、 2の画像 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: 手順 4、 3の画像 1 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: 手順 4、 3の画像 2 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: 手順 4、 3の画像 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: 手順 5、 3の画像 1 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: 手順 5、 3の画像 2 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: 手順 5、 3の画像 3
    • Remove the three silver Phillips screws from the plastic ring that holds the speaker in place.
    • Be careful not to rip out the speaker while taking out the screws
    • The same steps can be done on the other side of the speaker
  6. Zenbre SoundBank Z3 Speaker Grill Replacement: 手順 6、 3の画像 1 Zenbre SoundBank Z3 Speaker Grill Replacement: 手順 6、 3の画像 2 Zenbre SoundBank Z3 Speaker Grill Replacement: 手順 6、 3の画像 3
    • First, remove the speaker from the motherboard, then remove the ring that held the speaker in place.
    • These are the joints that need to be soldered. Follow this guide link to help you remove the wires from the motherboard.
    • How To Solder and Desolder Connections
  7. Zenbre SoundBank Z3 Speaker Grill Replacement: 手順 7、 2の画像 1 Zenbre SoundBank Z3 Speaker Grill Replacement: 手順 7、 2の画像 2
    • With the plastic ring removed, the speaker should slide out easily.
    • Be careful not remove other components in the speaker
    • This will expose the speaker grill
  8. Zenbre SoundBank Z3 Speaker Grill Replacement: 手順 8、 3の画像 1 Zenbre SoundBank Z3 Speaker Grill Replacement: 手順 8、 3の画像 2 Zenbre SoundBank Z3 Speaker Grill Replacement: 手順 8、 3の画像 3
    • Now that the speaker has been removed, the plastic grill should be visible.
    • With a little bit of force they can be pushed out.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Luc Josue Pierre Louis
メンバー登録日: 03/09/16
183 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 UMass Dartmouth, Team 3-2, Bhusal Spring 2016人のメンバー
UMASSD-BHUSAL-S16S3G2
5 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 514
