メインコンテンツにスキップ
Zeki TBQG884B LCD Screen Replacement
必要な工具と部品
  1. Zeki TBQG884B LCD Screen Replacement, Rear Case: 手順 1、 2の画像 1 Zeki TBQG884B LCD Screen Replacement, Rear Case: 手順 1、 2の画像 2
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B LCD Screen Replacement: 手順 2、 1の画像 1
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B LCD Screen Replacement: 手順 3、 2の画像 1 Zeki TBQG884B LCD Screen Replacement: 手順 3、 2の画像 2
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B LCD Screen Replacement, Motherboard: 手順 4、 1の画像 1
    • Disconnect the Wi-Fi antenna cable from the motherboard.
  5. Zeki TBQG884B LCD Screen Replacement: 手順 5、 1の画像 1
    • Using the Phillips #1 screwdriver, remove the three screws from the motherboard..
  6. Zeki TBQG884B LCD Screen Replacement: 手順 6、 1の画像 1
    • Open the ZIF connector. Then, remove the ribbon that connects the motherboard and the screen.
  7. Zeki TBQG884B LCD Screen Replacement: 手順 7、 1の画像 1
    • Disconnect the other ZIF connector on the opposite side of the motherboard.
  8. Zeki TBQG884B LCD Screen Replacement: 手順 8、 1の画像 1
    • Remove the motherboard and now reinsert all connectors into a new motherboard.
    • In order to disconnect the battery and speaker wires from the motherboard, soldering is required. Be cautious as the soldering iron is hot.
  9. Zeki TBQG884B LCD Screen Replacement, LCD Screen: 手順 9、 1の画像 1
    • Use an opening tool to detach the clip between the front frame, and the metal loader.
    • There are several clips on each side of the frame. Detach ALL of them before you open the loader.
  10. Zeki TBQG884B LCD Screen Replacement: 手順 10、 1の画像 1
    • Lift the metal loader up and separate it from the LCD screen.
    • Detach each piece slowly to avoid damaging or dropping any fragile parts.
終わりに
2 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
David Wyman
メンバー登録日: 09/16/15
346 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 1-3, Harley Fall 2015 IUPUI, Team 1-3, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S1G3
5 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 1,393
