メインコンテンツにスキップ
Zeki Droid Tablet Battery Replacement
必要な工具と部品
  1. Zeki Droid Tablet Battery Replacement, Back Casing: 手順 1、 1の画像 1
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Battery Replacement: 手順 2、 1の画像 1
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Battery Replacement: 手順 3、 1の画像 1
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Battery Replacement: 手順 4、 1の画像 1
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Battery Replacement: 手順 5、 1の画像 1
    • Pull the speakers away from the back casing carefullly.
  6. Zeki Droid Tablet Battery Replacement, Battery: 手順 6、 1の画像 1
    • To remove the battery use an iFixit opening tool to pry the battery apart from the sticky glue.
    • Do not bend the battery.
  7. Zeki Droid Tablet Battery Replacement: 手順 7、 1の画像 1
    • To completely disconnect the battery, locate the two metal tabs connected to the small circuit board.
    • Using a soldering tool, you will desolder the tabs from the circuit board.
    • Please refer to the はんだ付けとはんだ除去の作業ガイド
    • If your replacement battery already has the small circuit board attached, you can desolder the red and black wires connected to the mother board instead of the metal tabs.
  8. Zeki Droid Tablet Battery Replacement: 手順 8、 1の画像 1
    • To insert the new battery, you will need to solder the two new metal tabs back onto the small circuit board.
    • Please refer to はんだ付けとはんだ除去の作業ガイド
    • If you have the battery with the circuit board connected, then you can solder the red and black wires back to the mother board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Kyla
メンバー登録日: 03/11/15
156 ポイント
2のガイドは作成済み
チーム
Colorado Springs, Team 2-6, Panko Spring 2015 Colorado Springs, Team 2-6, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S2G6
3 メンバー
10のガイドは作成済み
2 件のコメント
will this be the same for a tbqc 1065b?
mark campbell - 返信
how do i replace the screen mine has cracks?
mark campbell - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 5,384
