メインコンテンツにスキップ
ZTE Quest n817 Power/Volume Button Replacement
必要な工具と部品
  1. ZTE Quest n817 Power/Volume Button Replacement, Battery: 手順 1、 3の画像 1 ZTE Quest n817 Power/Volume Button Replacement, Battery: 手順 1、 3の画像 2 ZTE Quest n817 Power/Volume Button Replacement, Battery: 手順 1、 3の画像 3
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Power/Volume Button Replacement: 手順 2、 2の画像 1 ZTE Quest n817 Power/Volume Button Replacement: 手順 2、 2の画像 2
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Power/Volume Button Replacement, Motherboard: 手順 3、 1の画像 1
    • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
  4. ZTE Quest n817 Power/Volume Button Replacement: 手順 4、 1の画像 1
    • Carefully pry open the back panel with the plastic opening tool.
  5. ZTE Quest n817 Power/Volume Button Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
  6. ZTE Quest n817 Power/Volume Button Replacement: 手順 6、 1の画像 1
    • Pull back the tape encasing the brown ribbon cable connector.
    • Remove the ribbon cable from its socket.
  7. ZTE Quest n817 Power/Volume Button Replacement: 手順 7、 1の画像 1
    • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
  8. ZTE Quest n817 Power/Volume Button Replacement: 手順 8、 2の画像 1 ZTE Quest n817 Power/Volume Button Replacement: 手順 8、 2の画像 2
    • Disconnect the coaxial connector in the bottom right corner of the motherboard.
  9. ZTE Quest n817 Power/Volume Button Replacement, Power/Volume Button: 手順 9、 1の画像 1
    • Each of these buttons can be removed using micro-soldering techniques around either side of the button.
    • Instructions for how to do so can be found at iFixit's How to Solder and Desolder Connections guide.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Eric Loureiro
メンバー登録日: 10/26/18
582 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S3-G6, Peak Fall 2018 UMass Dartmouth, Team S3-G6, Peak Fall 2018人のメンバー
UMASSD-PEAK-F18S3G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 287
