メインコンテンツにスキップ
ZTE Max XL Motherboard Replacement
必要な工具と部品
  1. ZTE Max XL Motherboard Replacement, Motherboard: 手順 1、 2の画像 1 ZTE Max XL Motherboard Replacement, Motherboard: 手順 1、 2の画像 2
    • Before any disassembly, make sure the phone is powered off.
    • Use the SIM Card Eject Tool to remove the SIM card tray. To do this, insert the key into the hole on the side of the phone near the SIM card tray.
  2. ZTE Max XL Motherboard Replacement: 手順 2、 1の画像 1
    • Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide.
    • On our phone there was adhesive on the top and bottom of the phone backing, so we specifically heated these areas.
    • Do not heat the phone too much in one area - it may warp the plastic backing.
  3. ZTE Max XL Motherboard Replacement: 手順 3、 3の画像 1 ZTE Max XL Motherboard Replacement: 手順 3、 3の画像 2 ZTE Max XL Motherboard Replacement: 手順 3、 3の画像 3
    • Starting at one corner, wedge a plastic opening pick or tool underneath the plastic backing to start undoing the tabs that connect the backing to the phone.
    • There are 3 tabs on top and bottom and 6 on each side.
  4. ZTE Max XL Motherboard Replacement: 手順 4、 2の画像 1 ZTE Max XL Motherboard Replacement: 手順 4、 2の画像 2
    • Remove the two 3.4 mm JIS #00 screws that hold the cable in place—one may be under a lock sticker.
  5. ZTE Max XL Motherboard Replacement: 手順 5、 1の画像 1
    • Use a nylon spudger to lift the press-fit connector and free the ribbon cable from the main part of the phone.
  6. ZTE Max XL Motherboard Replacement: 手順 6、 1の画像 1
    • Remove all nineteen 3.4 mm JIS #00 screws from the perimeter of the back.
  7. ZTE Max XL Motherboard Replacement: 手順 7、 1の画像 1
    • Use an opening tool between the screen and side trim battery cover to remove the screen.
  8. ZTE Max XL Motherboard Replacement: 手順 8、 2の画像 1 ZTE Max XL Motherboard Replacement: 手順 8、 2の画像 2
    • Use a nylon spudger to carefully lift the 6 press-fit connections free from the motherboard.
  9. ZTE Max XL Motherboard Replacement: 手順 9、 2の画像 1 ZTE Max XL Motherboard Replacement: 手順 9、 2の画像 2
    • Use the Spudger to carefully flip the metal clip holding the camera in place, located on the backside of the Motherboard.
  10. ZTE Max XL Motherboard Replacement: 手順 10、 1の画像 1
    • With the motherboard removed, you can now insert the new motherboard or replace other parts within your phone.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Juan Espejo
メンバー登録日: 03/30/22
211 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 1-2, Harley Spring 2022 IUPUI, Team 1-2, Harley Spring 2022人のメンバー
IUPUI-HARLEY-S22S1G2
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 131
