メインコンテンツにスキップ
ZTE Maven 2 Screen Replacement
必要な工具と部品
  1. ZTE Maven 2 Screen Replacement, Back Cover: 手順 1、 3の画像 1 ZTE Maven 2 Screen Replacement, Back Cover: 手順 1、 3の画像 2 ZTE Maven 2 Screen Replacement, Back Cover: 手順 1、 3の画像 3
    • Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
    • Work your way around the phone with an opening pick to loosen the rest of the back cover.
    • Remove the cover.
  2. ZTE Maven 2 Screen Replacement, Battery: 手順 2、 1の画像 1
    • Push in and then up on the bottom of the battery to free it from its compartment.
    • Pull the battery out.
  3. ZTE Maven 2 Screen Replacement, MicroSD Card: 手順 3、 2の画像 1 ZTE Maven 2 Screen Replacement, MicroSD Card: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
    • A SIM card is used to demonstrate the process for removing the MicroSD card in these images.
  4. ZTE Maven 2 Screen Replacement, Midframe: 手順 4、 1の画像 1
    • Remove the twelve 3 mm screws with a Phillips #00 screwdriver.
  5. ZTE Maven 2 Screen Replacement: 手順 5、 3の画像 1 ZTE Maven 2 Screen Replacement: 手順 5、 3の画像 2 ZTE Maven 2 Screen Replacement: 手順 5、 3の画像 3
    • Wedge the opening tool between the front and side panel to create a gap.
    • Slide the opening pick around the device to detach the midframe.
  6. ZTE Maven 2 Screen Replacement, Motherboard: 手順 6、 3の画像 1 ZTE Maven 2 Screen Replacement, Motherboard: 手順 6、 3の画像 2 ZTE Maven 2 Screen Replacement, Motherboard: 手順 6、 3の画像 3
    この手順で使用する道具:
    • Peel the sticker off the battery compartment, as some of the motherboard components are hidden under it.
    • Remove the six 3 mm screws with a Phillips #00 screwdriver.
    • Using a pair of blunt tweezers, carefully remove the black wire that's attached to the gold plates on the left side of the device.
  7. ZTE Maven 2 Screen Replacement: 手順 7、 2の画像 1 ZTE Maven 2 Screen Replacement: 手順 7、 2の画像 2
    • Using the opening tool, carefully detach the ribbon cables connected to the motherboard.
  8. ZTE Maven 2 Screen Replacement: 手順 8、 2の画像 1 ZTE Maven 2 Screen Replacement: 手順 8、 2の画像 2
    • Work the opening pick around the edges of the motherboard to loosen it up.
    • The motherboard is glued down with adhesive. Pushing firmly with the pick will help to loosen the components and remove them.
    • Pull the motherboard out of the device.
  9. ZTE Maven 2 Screen Replacement, Daughterboard: 手順 9、 1の画像 1
    • Remove the daughterboard containing the charging port.
  10. ZTE Maven 2 Screen Replacement, Screen: 手順 10、 1の画像 1
    この手順で使用する道具:
    • Detach the ribbon cable connecting the camera to the device.
    • Use blunt tweezers to pull the camera off.
    • What's left in your hands after removing the camera is the screen component. This is what gets replaced.
    • The screw holes for the midframe and motherboard overlap. Plan out which screws will go where.
終わりに
作成者
5人の作成者と共同で作成されました。
Hewot Takele
メンバー登録日: 09/06/22
73 ポイント
1ガイドが承認済み
チーム
University of Colorado Denver, Team 1-3, Campeau Fall 2022 University of Colorado Denver, Team 1-3, Campeau Fall 2022人のメンバー
UCDENVER-CAMPEAU-F22S1G3
5 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 296
