はじめに
This replacement guide will provide you with the necessary instructions to replace the speaker in the ZTE Compel. You may need to replace the speaker if there is no sound or if the sound quality is off.
必要な工具と部品
Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
Remove the 9 screws that measure 4 mm Phillips. Use your PH000 screwdriver attachment.
もう少しです!
終わりに
