はじめに
This guide shows how to remove or replace the motherboard cover in the Xiaomi Mi 9 including the charging coil / NFC antenna.
You’ll need replacement adhesive to reattach components when reassembling the device.
必要な工具と部品
Before you begin, switch off your phone.
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
6 の人々がこのガイドを完成させました。
2 件のコメント
dove trovo il modulo nfc?
