メインコンテンツにスキップ
Xgody D300 Headphone Jack Replacement
必要な工具と部品
  1. Xgody D300 Headphone Jack Replacement, Battery: 手順 1、 1の画像 1
    • Lay the phone on a flat surface so the back is facing upwards.
  2. Xgody D300 Headphone Jack Replacement: 手順 2、 1の画像 1
    • Insert the pry tool into the seam and pry the back cover of the case along the seam until the cover is free of the case.
  3. Xgody D300 Headphone Jack Replacement: 手順 3、 2の画像 1 Xgody D300 Headphone Jack Replacement: 手順 3、 2の画像 2
    • Remove the battery using your hands or the plastic opening tool.
  4. Xgody D300 Headphone Jack Replacement, Headphone Jack: 手順 4、 3の画像 1 Xgody D300 Headphone Jack Replacement, Headphone Jack: 手順 4、 3の画像 2 Xgody D300 Headphone Jack Replacement, Headphone Jack: 手順 4、 3の画像 3
    • There should be 14 screws with a length of 3mm and one screw with a length of 6m. Remove these screws using the Phillips #00 screwdriver.
    • Unscrew the three screws using the Phillips #00 screwdriver.
    • These screws cannot be removed from the device.
    • Lift the housing along the edges using the opening tool and tweezers. There will be a sticky pad that holds the housing to the smartphone.
  5. Xgody D300 Headphone Jack Replacement: 手順 5、 2の画像 1 Xgody D300 Headphone Jack Replacement: 手順 5、 2の画像 2
    • Using a soldering iron and desoldering pump, remove the soldered connections holding the headphone jack to the motherboard.
    • There should be 6 soldered connections holding the headphone jack to the motherboard.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
  6. Xgody D300 Headphone Jack Replacement: 手順 6、 1の画像 1
    • After the connections have been removed, the headphone jack will be free of the motherboard and will need to be removed. Remove the headphone jack by picking it up with tweezers.
    • Place the new headphone jack where the old one was and solder the connections back to together.
    • Your new Headphone Jack has been successfully installed!
終わりに
作成者
4人の作成者と共同で作成されました。
Kiara Richardson
メンバー登録日: 09/16/19
705 ポイント
5のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 138
