はじめに
This guide will show you how to replace the joystick on your Xbox Series X Wireless Controller (Model 1914) and fix stick drift.
Note: This guide requires soldering. For more information on soldering take a look at this guide for How to Solder and Desolder Connections.
Caution: The soldering iron gets very hot and can cause injury.
Note: It is also important to solder in a well-ventilated room.
必要な工具と部品
Have everything you will need on-hand at your workspace. This includes:
Your tools:
A Torx screwdriver with a T8 sized head (2.31mm) and a T6 sized head (1.70mm)
A soldering rod and solder
Spudger
Tweezers (optional)
The replacement joysticks
A clean, uncluttered place to work and keep your screws organized.
Next, take your opening tool and pry off the grip plates.
Using your opening tool, insert it into the grove found on the back of the grips.
Slide the tool throughout the groove, prying in the spots that you feel the most resistance until it comes free.
Repeat this until the grip cover comes off.
Do the same for the other grip.
After that, locate the RB and LB bumper piece and, using your metal spudger, place it between the frame and the hinge.
Gently pry the piece away and off, doing the same for the other end of the bumper piece.
Having done this successfully, the bumper piece should come off cleanly and with little effort.
Set the bumper piece off to the side.
Take the main piece and flip it over to show the main components.
Next, we will be removing both triggers.
Move the triggers forward and expose the back parts of the trigger.
Using the T6 sized bit, remove the screw from the trigger and place it safely off to the side.
Do the same for the other trigger and set the pieces off to the side.
Next, we will disconnect the wires for the select and menu buttons.
Using either your fingers or a set of tweezers, gently pull the connection up and away to disconnect it.
Do this for both connections.
While here, remove the two screws above the connections. These connect the motherboard to the frame.
Find the D-pad plate surrounding the outer rim of the D-pad.
Using your spudger, slide it underneath the piece and pull it up from the controller.
Remove the plate and set it to the side.
Taking off the plate should free the plastic D-pad. Remove it from the controller and place both the plate and cover to the side for now.
Flip the board over.
Locate the joystick solder nubs on the back of the bottom of the board.
Using the soldering iron, heat it up to around 350-375 degrees Fahrenheit, and then lay the tip on the aforementioned nubs.
Hold it for around 5-7 seconds or until the solder nub liquefies. Repeat this for the rest of the nubs.
Having done this, the joystick should slide out the board. Install the replacement joystick by sliding in the joystick prongs into the slots that the old joystick sat in.
With the joystick in, solder the prongs until they are secured into place on the boards.
ある他の人がこのガイドを完成しました。
