メインコンテンツにスキップ
必要な工具と部品
ビデオの概要
この分解は修理ガイドでは ありません。 お持ちのXbox One Xを修理する際は、iFixitの修理ガイドをご利用ください。
    まとめ
    • このコンソール全体を解体するには、数本の工具しか必要ありません。
    • 一度内部を開口すると、クリーンで理にかなったモジュール式のデザインが採用されているためドライブ、ファン、ヒートシンク、PSU、ワイヤレスボード、正面のサブ基板が簡単に交換できます。
    • 内部でロックされたボディパネルが少なく単純なクリップの配置により、前モデルに比べてこのXboxの開口はもっと簡単になりました。
    • ハードドライブを交換すると保証対象外となり、他の保証付きサービスを断念しなければなりません。
    リペアビリティのスコア
    8
    10点中8点のリペアビリティ
    (10点が最も修理しやすい指標です)
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
21 件のコメント
Uhg, the HDD reformat is the worst part. Why are we getting so many devices without guides? The video is more for entertainment than help for repair. I'd rather have less teardowns with complete guides. Last of all, why don't we get a Pixel 2 teardown? That's like getting a iPhone 8 plus teardown but no regular teardown. Especially considering the regular model is probably more popular.
George A. - 返信
Hi @pccheese! We’ll have guides eventually, but they take much longer to create than a teardown. You’re right, teardowns are not meant to be used as instructions and are no substitute for a proper guide. As far as Pixel 2, our team is small and we only had the bandwidth for a full teardown on one of the two Pixel phones. The XL was chosen in part because it has gotten more attention, due to the more dramatically updated design. FYI the vanilla Pixel 2’s internals look very, very similar to the original Pixel XL, but with the addition of the same Active Edge strain gauges we saw in the 2 XL.
Jeff Suovanen -
@jeffsu If you have these devices and you are tearing them down internally, perhaps iFixit can take the pictures and the community could write the guides. I have no problem writing the guides- but my photography setup isn't always set up when I'm about to fix something.
A proper step by step teardown is much more helpful for repair then a video. I'm sure people use the teardown all the time for repair on many devices.
George A. -
@jeffsu So what about the guides?
George A. -
Taking pictures is actually quite time-consuming, otherwise I’m sure we’d take you up on that. :) Bear with us a bit, the guidewriting team is down a few people so our pace is definitely not what we’d like it to be in terms of guide production at the moment. We’re working on it!
Jeff Suovanen -
コメントを追加
統計データ:
過去 24時間: 32
過去 7 日: 228
過去 30 日: 1,070
今までの合計 172,245
