メインコンテンツにスキップ
Xbox One Wireless Controller 1697 Rumble Motor Replacement
必要な工具と部品
  1. Xbox One Wireless Controller 1697 Rumble Motor Replacement, Bumpers: 手順 1、 1の画像 1
    • Remove the battery pack cover.
    • Remove the two AA batteries.
    • Carefully remove the sticker or puncture to reveal the screw.
  2. Xbox One Wireless Controller 1697 Rumble Motor Replacement: 手順 2、 3の画像 1 Xbox One Wireless Controller 1697 Rumble Motor Replacement: 手順 2、 3の画像 2 Xbox One Wireless Controller 1697 Rumble Motor Replacement: 手順 2、 3の画像 3
    • Remove the side handles by wedging the spudger around the side panels.
    • Pry the side panel by moving the spudger back and forth. You must do this along the entire seam to remove the side handle panel.
    • There are seven clips that need to be opened to remove each handle panel.
  3. Xbox One Wireless Controller 1697 Rumble Motor Replacement: 手順 3、 3の画像 1 Xbox One Wireless Controller 1697 Rumble Motor Replacement: 手順 3、 3の画像 2 Xbox One Wireless Controller 1697 Rumble Motor Replacement: 手順 3、 3の画像 3
    • Removing the side handles allows access to remove the faceplate.
    • Use the TORX TR8 screwdriver to remove the five TR9 Torx screws.
  4. Xbox One Wireless Controller 1697 Rumble Motor Replacement: 手順 4、 3の画像 1 Xbox One Wireless Controller 1697 Rumble Motor Replacement: 手順 4、 3の画像 2 Xbox One Wireless Controller 1697 Rumble Motor Replacement: 手順 4、 3の画像 3
    • Now that the bumpers are easily visible make sure to clean any dirt or grime that may be around the bumpers.
    • The bumpers are connected by a middle plastic cover that is around the Xbox home button. Remove this plastic piece by lifting the plastic cover over the two pins, pressing the home button in, and pushing the cover towards the top of the controller.
    • Be aware of the sync button loosely placed under the plastic covering. Ensure it is put back before putting back the bumper/plastic cover assembly.
    • Remove the current bumper assembly by pulling them off the plastic cover.
  5. Xbox One Wireless Controller 1697 Rumble Motor Replacement: 手順 5、 3の画像 1 Xbox One Wireless Controller 1697 Rumble Motor Replacement: 手順 5、 3の画像 2 Xbox One Wireless Controller 1697 Rumble Motor Replacement: 手順 5、 3の画像 3
    • The controller is now ready for the new bumper assembly.
    • Align the new bumpers onto the top of the controller by holding down the triggers and aligning the four pins on both sides.
    • Set the new home button cover over the micro USB port, push the home button in, and pull the cover over the two pins shown.
  6. Xbox One Wireless Controller 1697 Rumble Motor Replacement, Rumble Motor: 手順 6、 2の画像 1 Xbox One Wireless Controller 1697 Rumble Motor Replacement, Rumble Motor: 手順 6、 2の画像 2
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • Use the How to Solder and Desolder Connections guide on iFixit to correctly (de)solder the components in your device.
    • Use caution while using the soldering iron so you don't damage other components or hurt yourself.
  7. Xbox One Wireless Controller 1697 Rumble Motor Replacement: 手順 7、 1の画像 1
    • Remove the rumble motors.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ryan Burroughs
メンバー登録日: 09/25/17
1,178 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S9-G1, Remmell Fall 2017 USF Tampa, Team S9-G1, Remmell Fall 2017人のメンバー
USFT-REMMELL-F17S9G1
4 メンバー
14のガイドは作成済み
1件のガイドコメント
Péssimo tutorial. Não mostra a ordem dos fios para soldar os motores Rumble.
Não é a mesma qualidade quando os guias eram do próprio Ifixit.
Will F. (Will) - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 93
今までの合計 10,257
