メインコンテンツにスキップ
Xbox One S All Digital Edition Top Metal Shield Replacement
必要な工具と部品
  1. Xbox One S All Digital Edition Top Metal Shield Replacement, Plastic Enclosure: 手順 1、 3の画像 1 Xbox One S All Digital Edition Top Metal Shield Replacement, Plastic Enclosure: 手順 1、 3の画像 2 Xbox One S All Digital Edition Top Metal Shield Replacement, Plastic Enclosure: 手順 1、 3の画像 3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Top Metal Shield Replacement: 手順 2、 2の画像 1 Xbox One S All Digital Edition Top Metal Shield Replacement: 手順 2、 2の画像 2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Top Metal Shield Replacement: 手順 3、 2の画像 1 Xbox One S All Digital Edition Top Metal Shield Replacement: 手順 3、 2の画像 2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Top Metal Shield Replacement: 手順 4、 1の画像 1
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Top Metal Shield Replacement, Top Metal Shield: 手順 5、 2の画像 1 Xbox One S All Digital Edition Top Metal Shield Replacement, Top Metal Shield: 手順 5、 2の画像 2
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Top Metal Shield Replacement: 手順 6、 3の画像 1 Xbox One S All Digital Edition Top Metal Shield Replacement: 手順 6、 3の画像 2 Xbox One S All Digital Edition Top Metal Shield Replacement: 手順 6、 3の画像 3
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jules Hajjar
メンバー登録日: 10/10/19
1,531 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team S12-G6, Regan Fall 2019 Cal Poly, Team S12-G6, Regan Fall 2019人のメンバー
CPSU-REGAN-F19S12G6
4 メンバー
26のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 694
