メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xbox 360 Wireless Controller Buttons Replacement
必要な工具と部品
  1. Xbox 360 Wireless Controller Buttons Replacement, Battery: 手順 1、 2の画像 1 Xbox 360 Wireless Controller Buttons Replacement, Battery: 手順 1、 2の画像 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
    FixBotに聞いてみる
    コメントを追加
  2. Xbox 360 Wireless Controller Buttons Replacement, Rear Case: 手順 2、 1の画像 1
    この手順で使用する道具:
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
    FixBotに聞いてみる
    コメントを追加
  3. Xbox 360 Wireless Controller Buttons Replacement: 手順 3、 1の画像 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
    FixBotに聞いてみる
    コメントを追加
  4. Xbox 360 Wireless Controller Buttons Replacement: 手順 4、 2の画像 1 Xbox 360 Wireless Controller Buttons Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    Spudger
    $2.99
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
    FixBotに聞いてみる
    コメントを追加
  5. Xbox 360 Wireless Controller Buttons Replacement: 手順 5、 2の画像 1 Xbox 360 Wireless Controller Buttons Replacement: 手順 5、 2の画像 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
    FixBotに聞いてみる
    コメントを追加
  6. Xbox 360 Wireless Controller Buttons Replacement: 手順 6、 2の画像 1 Xbox 360 Wireless Controller Buttons Replacement: 手順 6、 2の画像 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
    FixBotに聞いてみる
    コメントを追加
  7. Xbox 360 Wireless Controller Buttons Replacement, Vibration Motors: 手順 7、 2の画像 1 Xbox 360 Wireless Controller Buttons Replacement, Vibration Motors: 手順 7、 2の画像 2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
    FixBotに聞いてみる
    コメントを追加
  8. Xbox 360 Wireless Controller Buttons Replacement: 手順 8、 2の画像 1 Xbox 360 Wireless Controller Buttons Replacement: 手順 8、 2の画像 2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
    FixBotに聞いてみる
    コメントを追加
  9. Xbox 360 Wireless Controller Buttons Replacement, Logic Board: 手順 9、 2の画像 1 Xbox 360 Wireless Controller Buttons Replacement, Logic Board: 手順 9、 2の画像 2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
    FixBotに聞いてみる
    コメントを追加
  10. Xbox 360 Wireless Controller Buttons Replacement, Buttons: 手順 10、 1の画像 1
    • Remove the rubber pad from the back of the input buttons.
    FixBotに聞いてみる
    コメントを追加
  11. Xbox 360 Wireless Controller Buttons Replacement: 手順 11、 2の画像 1 Xbox 360 Wireless Controller Buttons Replacement: 手順 11、 2の画像 2
    この手順で使用する道具:
    • Using a pair of tweezers, remove the buttons from the front case.
    • A Button
    • B Button
    • X Button
    • Y Button
    • Start Button
    • Select Button
    • Guide Button
    FixBotに聞いてみる
    コメントを追加
  12. Xbox 360 Wireless Controller Buttons Replacement: 手順 12、 1の画像 1
    • Using a pair of tweezers, lift the home button's LED ring out of the front case of the controller.
    • All of the buttons have tabs that correspond to slots in the front case. This prevents buttons from being placed in the incorrect position or orientation.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
68 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Brett Hartt
メンバー登録日: 04/12/10
132,251 ポイント
144のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
30,155のガイドは作成済み
3件のガイドコメント
Hello I have had an Xbox for about 1-2years and everything has been working fine until the A button on one of my controllers stopped working I don't think it has gunk or anything because I can press it down and it comes back up just that when I press it in screen nothing happens but the other buttons work fine
Saul Escalon - 返信 共有
Thank you for the teardown! My cat has just vomitted on my joystick…. I could have cleaned it now! I appreciate it , thanks…
Nathan St-Onge - 返信 共有
Has anyone ever replaced the spring contacts in the logic board???
BJ Robbins - 返信 共有
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 83
過去 30 日: 448
今までの合計 78,963
