はじめに
This guide will involve the replacement of the core motor servos that steers the X-Street SRT Viper. The model of the core motor that you will need to buy to replace this part is the CL-FC130 motor produced by the Guangdong Chaoli Motor Machinery Co. Reinstalling the motor will require you to re-solder the wires back on. Core Motor Replacement Part
必要な工具と部品
Remove the four 3 mm screws from the bottom panel using a 3 mm Philips #1 screwdriver.
Begin by removing all underside panels of the car. You can do this by referring to the prerequisite up to this point.
Remove screws. Take your #1 Phillips head screwdriver and remove the six 8mm Phillips #1 screws holding down the panel above the servos motor.
Solder wires back on. The last step will be to solder the red wire back on the left side of the motor and the black wire back on the right side. You can do this by referring to this how to solder/desolder page.
ある他の人がこのガイドを完成しました。
