メインコンテンツにスキップ
Whirlpool WED87HED Dryer Door Switch Testing and Replacement
必要な工具と部品
  1. Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Safety Precautions: 手順 1、 1の画像 1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Unfasten the top panel: 手順 2、 3の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Unfasten the top panel: 手順 2、 3の画像 2 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Unfasten the top panel: 手順 2、 3の画像 3
    この手順で使用する道具:
    FixMat
    $31.41
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a 5/16 inch nut driver to remove the two 15.7 mm-long screws securing the top panel to the rear panel bracket.
  3. Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Remove the top panel: 手順 3、 2の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Remove the top panel: 手順 3、 2の画像 2
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool WED87HED Dryer Door Switch Testing and Replacement: 手順 4、 2の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement: 手順 4、 2の画像 2
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Disconnect the control panel: 手順 5、 2の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Disconnect the control panel: 手順 5、 2の画像 2
    • Disconnect the control panel cable from the main board.
  6. Whirlpool WED87HED Dryer Door Switch Testing and Replacement: 手順 6、 2の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement: 手順 6、 2の画像 2
    • Disconnect the drum light connector.
  7. Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Unfasten the control panel: 手順 7、 2の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Unfasten the control panel: 手順 7、 2の画像 2
    • Use a 1/4 inch nut driver to remove the two 16.3 mm‑long sheet metal screws located at each end of the control panel.
  8. Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Remove the control panel: 手順 8、 3の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Remove the control panel: 手順 8、 3の画像 2 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Remove the control panel: 手順 8、 3の画像 3
    • Lift the control panel up and tilt it away from the chassis to remove it.
    • Make sure to thread the cable through the hole in the chassis.
    • During reassembly, thread the cable through its proper hole before reinstalling the control panel.
  9. Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Disconnect the door switch: 手順 9、 3の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Disconnect the door switch: 手順 9、 3の画像 2 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Disconnect the door switch: 手順 9、 3の画像 3
    • Use a small flat blade screwdriver or a spudger to unlatch both sides of the door switch connector.
    • Unplug the connector.
  10. Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Unfasten the front panel: 手順 10、 2の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Unfasten the front panel: 手順 10、 2の画像 2
    • Use a 1/4 inch nut driver to remove the three upper front panel 16.4 mm-long sheet metal screws.
    • Tilt the machine backwards and prop it securely, or have a friend hold it.
    • Use a 1/4 inch nut driver to remove the four sheet metal screws on the bottom edge of the panel:
    • Two 16.4 mm screws
    • Two 13 mm screws
  11. Whirlpool WED87HED Dryer Door Switch Testing and Replacement: 手順 11、 1の画像 1
    • Use a Phillips driver to remove the two 15.8 mm‑long screws inside the door area below the drum opening.
  12. Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Remove the front panel: 手順 12、 3の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Remove the front panel: 手順 12、 3の画像 2 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Remove the front panel: 手順 12、 3の画像 3
    • The panel is heavy and awkward. You may want to have a friend help you with this step.
    • Pull the bottom of the panel away from the chassis about two to three inches.
    • Lift the front panel off the small tabs on the chassis near the top of the panel and remove it.
    • Make sure you don't snag the door switch wire harness as you remove the panel.
  13. Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Release the door switch harness: 手順 13、 3の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Release the door switch harness: 手順 13、 3の画像 2 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Release the door switch harness: 手順 13、 3の画像 3
    • Use slip joint pliers to pinch the tabs of the harness clip.
    • Push the clip through the mounting hole to release the door switch harness.
  14. Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Remove the door switch: 手順 14、 3の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Remove the door switch: 手順 14、 3の画像 2 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Remove the door switch: 手順 14、 3の画像 3
    • Working from the rear of the front panel, pinch the tabs on the end of the switch toward the switch body to release it.
    • The tabs are kind of quirky. They need to be pushed in a diagonal direction to release them. When they do release, you will know it.
    • Push the switch through the mounting hole toward the front of the panel.
  15. Whirlpool WED87HED Dryer Door Switch Testing and Replacement: 手順 15、 2の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement: 手順 15、 2の画像 2
    • Feed the harness through the mounting hole to remove the switch.
    • The second photo shows the switch removed so you can see the mounting flange. This flange is on the front of the switch and faces the dryer door.
  16. Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Test the switch: 手順 16、 2の画像 1 Whirlpool WED87HED Dryer Door Switch Testing and Replacement, Test the switch: 手順 16、 2の画像 2
    • This step shows how to test the switch, which will require a multimeter. If you aren't familiar with how to use one, here is a guide that will help you.
    • Insert the multimeter's probes into the two outermost sockets on the switch connector and test continuity and open on the door switch.
    • When the button on the switch is not pushed, the meter should indicate OL.
    • When the button is pushed with the probes in the same place, the meter should read less than 1 Ω.
    • If either of these readings is wrong, especially with the button pressed, replace the switch.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
作成者
3人の作成者と共同で作成されました。
Bill Gilbert
メンバー登録日: 06/30/22
38,497 ポイント
261のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,611のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 25
過去 30 日: 95
今までの合計 1,543
