メインコンテンツにスキップ
Whirlpool Refrigerator Freezer Thermistor Replacement
必要な工具と部品
  1. Whirlpool Refrigerator Freezer Thermistor Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: 手順 2、 3の画像 1 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: 手順 2、 3の画像 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: 手順 2、 3の画像 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: 手順 3、 2の画像 1 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: 手順 3、 2の画像 2
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Freezer Thermistor Replacement: 手順 4、 2の画像 1 Whirlpool Refrigerator Freezer Thermistor Replacement: 手順 4、 2の画像 2
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: 手順 5、 3の画像 1 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: 手順 5、 3の画像 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: 手順 5、 3の画像 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: 手順 6、 3の画像 1 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: 手順 6、 3の画像 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: 手順 6、 3の画像 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: 手順 7、 3の画像 1 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: 手順 7、 3の画像 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: 手順 7、 3の画像 3
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: 手順 8、 2の画像 1 Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: 手順 8、 2の画像 2
    • Disconnect any connectors attached to the thermistor.
  9. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the thermistor: 手順 9、 1の画像 1
    • Remove the thermistor.
  10. Whirlpool Refrigerator Freezer Thermistor Replacement, Meter the thermistor: 手順 10、 1の画像 1
    • If you own a multimeter, you can test your thermistor's resistance.
    • A range between 2-220KΩ is acceptable. Check the specifications for your specific thermistor since there is such a large variance, and make sure you test at the appropriate temperature.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,927 ポイント
88のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
35 メンバー
603のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 30
過去 30 日: 134
今までの合計 1,918
