メインコンテンツにスキップ
Whirlpool Refrigerator Evaporator Fan Replacement
必要な工具と部品
  1. Whirlpool Refrigerator Evaporator Fan Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: 手順 2、 3の画像 1 Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: 手順 2、 3の画像 2 Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: 手順 2、 3の画像 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the drawers: 手順 3、 2の画像 1 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the drawers: 手順 3、 2の画像 2
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Evaporator Fan Replacement: 手順 4、 2の画像 1 Whirlpool Refrigerator Evaporator Fan Replacement: 手順 4、 2の画像 2
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: 手順 5、 3の画像 1 Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: 手順 5、 3の画像 2 Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: 手順 5、 3の画像 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: 手順 6、 3の画像 1 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: 手順 6、 3の画像 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: 手順 6、 3の画像 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan: 手順 7、 2の画像 1 Whirlpool Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan: 手順 7、 2の画像 2
    • Use needle nose pliers, or your fingers, to disconnect the grounding wire(s) attached to the evaporator fan.
  8. Whirlpool Refrigerator Evaporator Fan Replacement: 手順 8、 3の画像 1 Whirlpool Refrigerator Evaporator Fan Replacement: 手順 8、 3の画像 2 Whirlpool Refrigerator Evaporator Fan Replacement: 手順 8、 3の画像 3
    • Disconnect any connectors attached to the evaporator fan.
  9. Whirlpool Refrigerator Evaporator Fan Replacement, Unfasten the evaporator fan: 手順 9、 1の画像 1
    • Remove the screw(s) securing the evaporator fan.
  10. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: 手順 10、 3の画像 1 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: 手順 10、 3の画像 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: 手順 10、 3の画像 3
    • Slide the foam buffer downward to release it from its lip in the chassis.
    • Remove the foam buffer.
    • Repeat this procedure any remaining foam buffers.
  11. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: 手順 11、 3の画像 1 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: 手順 11、 3の画像 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: 手順 11、 3の画像 3
    • Pull the evaporator fan housing up and outward from the chassis to remove it.
  12. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the fan: 手順 12、 2の画像 1 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the fan: 手順 12、 2の画像 2
    • Pull the evaporator fan straight off its motor to remove it.
    • This may require some significant force.
  13. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 手順 13、 3の画像 1 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 手順 13、 3の画像 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 手順 13、 3の画像 3
    • Use your fingers to pry up and release the motor bracket clips from the housing.
  14. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 手順 14、 2の画像 1 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 手順 14、 2の画像 2
    • Remove the motor bracket.
  15. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: 手順 15、 3の画像 1 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: 手順 15、 3の画像 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: 手順 15、 3の画像 3
    • Pull the motor straight out of its housing to remove it.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,927 ポイント
88のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
35 メンバー
603のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 67
過去 30 日: 463
今までの合計 4,697
