メインコンテンツにスキップ
Whirlpool Refrigerator Door Seal Replacement
必要な工具と部品
  1. Whirlpool Refrigerator Door Seal Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Door Seal Replacement, Open the doors: 手順 2、 3の画像 1 Whirlpool Refrigerator Door Seal Replacement, Open the doors: 手順 2、 3の画像 2 Whirlpool Refrigerator Door Seal Replacement, Open the doors: 手順 2、 3の画像 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Door Seal Replacement, Disconnect the door seal: 手順 3、 3の画像 1 Whirlpool Refrigerator Door Seal Replacement, Disconnect the door seal: 手順 3、 3の画像 2 Whirlpool Refrigerator Door Seal Replacement, Disconnect the door seal: 手順 3、 3の画像 3
    • Insert an opening tool, or a similar tool, between the door frame and the seal.
    • Pry up to separate the seal from its groove on the frame.
    • This may take significant force.
  4. Whirlpool Refrigerator Door Seal Replacement, Remove the door seal: 手順 4、 3の画像 1 Whirlpool Refrigerator Door Seal Replacement, Remove the door seal: 手順 4、 3の画像 2 Whirlpool Refrigerator Door Seal Replacement, Remove the door seal: 手順 4、 3の画像 3
    • Use your hand and the opening tool to peel the door seal away from the frame.
    • Repeat this process for the perimeter of the door seal until the seal is completely separated.
  5. Whirlpool Refrigerator Door Seal Replacement, Only the door seal remains: 手順 5、 3の画像 1 Whirlpool Refrigerator Door Seal Replacement, Only the door seal remains: 手順 5、 3の画像 2 Whirlpool Refrigerator Door Seal Replacement, Only the door seal remains: 手順 5、 3の画像 3
    • You're now left with the door seal.
    • During reassembly, perform the following:
    • Use a Jimmy, or a similar tool, to remove any sealing foam in the door frame groove.
    • Use a mild cleaning solution to fully clean the groove.
    • Reinstall your door by attaching the top edge first, then wrapping the seal around the frame's perimeter.
    • You'll hear the gasket lock into the seam.
    • You may have to stretch the seal a few inches at the final edge.
  6. Whirlpool Refrigerator Door Seal Replacement, Perform a seal test: 手順 6、 3の画像 1 Whirlpool Refrigerator Door Seal Replacement, Perform a seal test: 手順 6、 3の画像 2 Whirlpool Refrigerator Door Seal Replacement, Perform a seal test: 手順 6、 3の画像 3
    • To test if your replacement door seal is working, perform the following:
    • Open the door slightly and insert a clean, flat bill between the door seal and the frame.
    • Close the door and slowly drag the bill away from the device.
    • If the seal is tight, then you should feel a moderate amount of resistance in the bill.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
作成者
2人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,927 ポイント
89のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
45 メンバー
700のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 34
過去 30 日: 110
今までの合計 3,219
