メインコンテンツにスキップ
Whirlpool Refrigerator Door Light Replacement
必要な工具と部品
  1. Whirlpool Refrigerator Door Light Replacement, Open the doors: 手順 1、 3の画像 1 Whirlpool Refrigerator Door Light Replacement, Open the doors: 手順 1、 3の画像 2 Whirlpool Refrigerator Door Light Replacement, Open the doors: 手順 1、 3の画像 3
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Door Light Replacement, Unclip the door light: 手順 2、 2の画像 1 Whirlpool Refrigerator Door Light Replacement, Unclip the door light: 手順 2、 2の画像 2
    • Be careful during this step, as it's easy to scratch the interior of the fridge or crack cold and brittle plastic.
    • Carefully insert a flathead screwdriver, or a similar tool, between the door light and the chassis.
    • Pry up to separate the door light enough so you can grip it with your fingers.
  3. Whirlpool Refrigerator Door Light Replacement: 手順 3、 3の画像 1 Whirlpool Refrigerator Door Light Replacement: 手順 3、 3の画像 2 Whirlpool Refrigerator Door Light Replacement: 手順 3、 3の画像 3
    • Tilt the door light downward to completely release its plastic clips.
    • Pull the light down to expose its connectors.
  4. Whirlpool Refrigerator Door Light Replacement: 手順 4、 3の画像 1 Whirlpool Refrigerator Door Light Replacement: 手順 4、 3の画像 2 Whirlpool Refrigerator Door Light Replacement: 手順 4、 3の画像 3
    • Disconnect any connectors attached to the door light.
    • Remove the door light.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
作成者
3人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,945 ポイント
89のガイドは作成済み
2件のガイドコメント
Hello Gents,
I have a Kitchen aid fridge Model # KRFF300ESS01 and one of the top Led light is flickering they come as a set module # W10897058, and connected by interconnecting wiring, (concealed in the panel) can any one please help me as to how I can change them out.....the other light is good and there is a screw which holds up the plastic panel housing the lights, can I get them out by removing the panel or do I get them out by taking them out one at a time and how do I get the wiring in like that .....cant post any pictures but will appreciate any feed back,
ashley demonte - 返信
I have LED lights on sides and top. All three top lights are out, but side lights are still on. What can cause this?
Moose - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 37
過去 30 日: 188
今までの合計 15,617
