メインコンテンツにスキップ
Whirlpool Refrigerator Dispenser Solenoid Replacement
必要な工具と部品
  1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Dispenser Solenoid Replacement, Open the doors: 手順 2、 3の画像 1 Whirlpool Refrigerator Dispenser Solenoid Replacement, Open the doors: 手順 2、 3の画像 2 Whirlpool Refrigerator Dispenser Solenoid Replacement, Open the doors: 手順 2、 3の画像 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker tray: 手順 3、 2の画像 1 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker tray: 手順 3、 2の画像 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Dispenser Solenoid Replacement, Unfasten the icemaker assembly: 手順 4、 2の画像 1 Whirlpool Refrigerator Dispenser Solenoid Replacement, Unfasten the icemaker assembly: 手順 4、 2の画像 2
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker assembly: 手順 5、 3の画像 1 Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker assembly: 手順 5、 3の画像 2 Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker assembly: 手順 5、 3の画像 3
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 手順 6、 3の画像 1 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 手順 6、 3の画像 2 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 手順 6、 3の画像 3
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker assembly: 手順 7、 1の画像 1
    • Remove the icemaker assembly.
  8. Whirlpool Refrigerator Dispenser Solenoid Replacement, Unfasten the icemaker auger assembly: 手順 8、 1の画像 1
    • Remove the screw(s) securing the icemaker auger assembly.
  9. Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 手順 9、 3の画像 1 Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 手順 9、 3の画像 2 Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 手順 9、 3の画像 3
    • Pull the icemaker auger assembly off of its slot in the chassis.
  10. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 手順 10、 3の画像 1 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 手順 10、 3の画像 2 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 手順 10、 3の画像 3
    • Disconnect any connectors attached to the icemaker auger assembly.
  11. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker auger assembly: 手順 11、 1の画像 1
    • Remove the icemaker auger assembly.
  12. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the dispenser: 手順 12、 3の画像 1 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the dispenser: 手順 12、 3の画像 2 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the dispenser: 手順 12、 3の画像 3
    • Slide the dispenser head out of its slot in the icemaker auger assembly.
  13. Whirlpool Refrigerator Dispenser Solenoid Replacement: 手順 13、 2の画像 1 Whirlpool Refrigerator Dispenser Solenoid Replacement: 手順 13、 2の画像 2
    • Remove the dispenser head out of its metal solenoid cube.
  14. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the tape: 手順 14、 3の画像 1 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the tape: 手順 14、 3の画像 2 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the tape: 手順 14、 3の画像 3
    • Peel the tape off the solenoid connector.
    • Set the tape aside. You'll reuse it during reassembly.
  15. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the solenoid: 手順 15、 3の画像 1 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the solenoid: 手順 15、 3の画像 2 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the solenoid: 手順 15、 3の画像 3
    • Disconnect the connector attached to the solenoid.
  16. Whirlpool Refrigerator Dispenser Solenoid Replacement, Meter the solenoid: 手順 16、 1の画像 1
    • If you own a multimeter, you can test your solenoid's resistance.
    • A range between 10-500Ω is acceptable. Check your fridge solenoid specs sheet for more details. The pictured solenoid measured at 33.9Ω.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
作成者
2人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,927 ポイント
89のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
45 メンバー
702のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 48
今までの合計 886
