メインコンテンツにスキップ
Whirlpool Refrigerator Defrost Heater Replacement
必要な工具と部品
  1. Whirlpool Refrigerator Defrost Heater Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: 手順 2、 3の画像 1 Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: 手順 2、 3の画像 2 Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: 手順 2、 3の画像 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Defrost Heater Replacement, Remove the drawers: 手順 3、 2の画像 1 Whirlpool Refrigerator Defrost Heater Replacement, Remove the drawers: 手順 3、 2の画像 2
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Defrost Heater Replacement: 手順 4、 2の画像 1 Whirlpool Refrigerator Defrost Heater Replacement: 手順 4、 2の画像 2
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: 手順 5、 3の画像 1 Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: 手順 5、 3の画像 2 Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: 手順 5、 3の画像 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: 手順 6、 3の画像 1 Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: 手順 6、 3の画像 2 Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: 手順 6、 3の画像 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: 手順 7、 3の画像 1 Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: 手順 7、 3の画像 2 Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: 手順 7、 3の画像 3
    • Disconnect the connector(s) attached to the defrost heater.
  8. Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: 手順 8、 3の画像 1 Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: 手順 8、 3の画像 2 Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: 手順 8、 3の画像 3
    • Pull the defrost heater cable out from behind the evaporator.
  9. Whirlpool Refrigerator Defrost Heater Replacement, Unfasten the defrost heater bracket: 手順 9、 1の画像 1
    • Remove the screw(s) securing the defrost heater bracket.
  10. Whirlpool Refrigerator Defrost Heater Replacement, Release the defrost heater bracket: 手順 10、 2の画像 1 Whirlpool Refrigerator Defrost Heater Replacement, Release the defrost heater bracket: 手順 10、 2の画像 2
    • Pull the defrost heater bracket up to release it from its slot in the chassis.
  11. Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: 手順 11、 3の画像 1 Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: 手順 11、 3の画像 2 Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: 手順 11、 3の画像 3
    • Slide the defrost heater from under the evaporator.
    • You may need to pull one end at a time until it's completely removed.
  12. Whirlpool Refrigerator Defrost Heater Replacement, Only the defrost heater remains: 手順 12、 1の画像 1
    • You're now left with the defrost heater.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
nicO
メンバー登録日: 04/14/15
15,927 ポイント
89のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
45 メンバー
700のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 24
過去 30 日: 121
今までの合計 3,921
